Upgrade 112X/FC2/150X
Posted by: andyharc on 02 October 2015
I upgraded the 112X/FC2 in my system to a 202/NASPC/FC2. Big difference! It sounds like it has quite a bit more zip to it! It is a bit brighter I think! Overall however I am very pleased. Now I need to spend some more time with it but so far so good! One question is the FC2 a good power supply to use with the 202 or should I look at something else a high cap??
