Hi,
I want to convert an old Nait 3 to a power amp.
I know Naim used to supply a conversion kit years ago with parts and instructions,
I searched on ebay and found none.
Anyone knows where can I get the instructions for this? Maybe someone has a them?
Has anyone done this conversion and can explain the process? I know it shouldn't be too complex...
Benny
Posted on: 05 October 2015 by Becks
OK, I wasn't aware of that, sorry.
I don't think there is an official dealer where I live, I could ask one of the shops to contact Naim for me.
Do you know if Naim still supplies theses kits?
Posted on: 05 October 2015 by Richard Dane
Becks, you will need to ask Naim. FWIW, what you want is possible if you are using a late NAIT 3/3R. This can provide the extra socket you need, otherwise, as Brilliant says, the kit only converts to a pre-amp.
Otherwise you're better off selling the NAIT 3 and buying a NAP90 and perhaps pocketing a little money along the way.
