New to this Forum
Posted by: Nooner on 07 October 2015
Hi everybody, just signed up from Switzerland.
Now back to Naim after a long break since 1989.
Starting with Mu-so was really impressive now located in the dining room.
For my classics I use the Imac+Hugo with HD 800, really nice.
Now trying to find out the smartest way of building up a system for my very small listening room, (only 15 sqm).
Not into vinyl, I think Hugo could work as a pre-amp together with Imac itunes Amarra and Tidal.
Listening at low levels mostly
Option 1
Hugo into high sensitivity speakers
Focal Electra 1008 BE or Diablo?
any other ideas?
Qption 2
Hugo directly into Nap 250, into Diablo
Option 3
Hugo into Supernait into Diablo
Any experience with these combinations?
I'm not sure the Hugo has enough power to work with speakers, except possibly full horn designs (which give 105dB or more per watt)
i don't have experience of the specifics you mention, but for me the Hugo works well powering an old Musical Fidelity P270 direct, sounding better than when I had played through a Tag McLaren PA10 preamp.
The Hugo's volume control takes a little getting used to compared to a standard knob! but is not an issueinitial volume setting on switch on is pleasantly loud for most source material, and provides ample range for quiet listening or really loud playing even with quiet recordings.
you've nothing to lose trying without a pre-amp, as the worst you have to do is get one if you don't find it suits!
Sounds like good questions for the Chord forum.
Hugo works very well into SN, I use mine with an SN2 to good effect. It is also possible to use it to drive an amp although its a bit of a pain getting up to turn up/down the volume. I used mine with a Nap100 which worked well. No idea how it would work on a Nap 250. Unless the speakers are active I can't see how it would drive a set of speakers but I haven't tried it and wouldn't know how to do so with the outputs on the Hugo.
Further to my reference to horn loudspeakers, I believe the hugo is capable of something like 2W output max, which with full horn speakers (bass as well, not just horn HF) could give maybe 108 to 113dB max, assuming it is capable of providing that into the loudsspeaker impedance, and assuming 15-110dB/W Speaker sensitivity.
If that rating is absolute, it will mean maximum peak level not just average, but should allow reasonable levels in a moderately sized room. non-horn loudspeakerns at 10dB lower even for efficient ones will be quiet.
Gents
Thank you for your quick answers.
Yeah may be I am a bit off site with the Hugo, anyhow love the Naim Sound at the end of the outcome, if that is ever possible with this little miracle.
It is just what I will try?
Supernait with Focal Diablo?
And then save up for a better Amp?
All the best
Jorg
You may be surprised how good it will sound into a SN. I have no experience of the Diablos so can't comment
Thanks dayjar
I will give it a try at my local dealer, the diabolos are just in my mind because of a good deal a friend of mine gave to me. SN may be the right solution for my limited space in my listening room.
Best regards from Swiss
Jorg
Why don't you take the yugo out of the equation and enjoy the real Naim sound with a NAC 272 + NAP 250Dr combination or buy a Superuniti ?
well the reason I am asking experienced fellows is to save time
If you do not know Hugo, that is OK.
272 will not match Hugo sorry to say
250 DR or 300 DR might be a solution as an Amp for Hugo
Pre Amps mess up the magic I was told...
Best Jorg
You may also have been told that the moon is made of cheese.
Naim power amps don't work well without a Naim preamp feeding them !
earth is flat, at least in the world of economists
People to find new ways to make our sounds more beautiful and work very hard on an unforgiving subject deserve respect. This respect is not given from myself only.
Best regards from CH
Sorry to say you may not know but the moon's a balloon and cheese is no match for that I have been reliably informed.
SJB
I love Cheese
Being Swiss
so cool you guys
Why is that?
Yes they can.
The NAP 100 directly fed from a fifty five year old tuner cum pre-amp from Leak made the 100 sound a million dollars, and the the Leak fell down, but it will do it again!
No rule is complete without an acknowledged exception!
ATB from George
SJB
Well the cheese is known at my place, the moon remains with the unfaithful...
Best
JR
Because you can't hear anything. ![]()
still enough to know, like Ludwig composing the 9TH without that privilege of hearing
Not old enough
Jorg
Yes they can.
ATB from George
Well Nooner why do you assume that I don't know the yugo ?
In my opinion the yugo mess up the magic and a good preamp (which is not the yugo: the yugo is a highly regarded headphone DAC) is the base of good sound quality (at least in a Naim setup).
You asked a suggestion in a Naim forum and me and other fellow forum members are answering your question: if you don't like our answers and if you are just looking for accondescending followers it's your problem.
P.S. I'm Italian and I also like cheese ! Smile and relax: it's all about a wonderful hobby that has many facets and not a univocal black or white truth !
Whilst I can't comment on other amps etc etc I can, from personal experience, confirm that the nap100 works very well indeed with a Hugo feeding it (rather better than with a UQ2 feeding it too)
Yes they can.
ATB from George
Naim power amps (RARELY) work well without a Naim preamp feeding them !
