Remote not working after updating firmware
Posted by: iwcpilot on 07 October 2015
I updated my Superuniti firmware to version 4.4 last night successfully and everything is working perfectly except my remote is now not working. I installed two different sets of fresh batteries (tested) and still no luck. I read on the forum about resetting the remote by pushing "aux", "i", and "disp" keys all at once but it did not do anything. I am not sure what to do now. I am looking for advice from anyone who has run into a similar problem. Thanks
Posted on: 07 October 2015 by GraemeH
I had the same thing happen when I updated my NDX to 4.3.3 but switching the unit off removing and reinstalling the batteries and switching the unit back on did the trick.
Good luck.
Posted on: 07 October 2015 by trickydickie
You need to power down first then hold the aux, i and disp whilst switching on.
Richard
Posted on: 07 October 2015 by iwcpilot
Thank you Richard. I will try that tonight.
I just noticed your pseudonym - I wear a MK XII Automatic!
I am a proud owner of a 3717 pilot chrono and 5009 Big Pilot.
Posted on: 07 October 2015 by Ingenius
Portafino chronograph with milanese mesh bracelet for me, just love IWC .. As well as my Rolex Gmt master 2
sorry for the hijack
regards
ing
I tried what Richard suggested without success. The remote still does not work. Any other suggestions? I am at a loss and don't know what to do next.
Posted on: 07 October 2015 by nudgerwilliams
Suggest you email  Naim Support.  Details in the sticky thread.  They are usually very responsive.
I sent them a note. Thanks for the suggestion.
