If you had to do in cabinet speakers
Posted by: DQ on 16 October 2015
Hello all,
For a 2nd system we need to do some downward firing loudspeakers. They will be in cabinetry.
I have been looking at Linn. They will be fed by something like a unitiqute.
Would appreciate any recommendations.
Posted on: 17 October 2015 by b_lund
Do you mean in-wall ?
Posted on: 17 October 2015 by DQ
Yes I do. They will actually not be in the ceiling but rather in some cabinetry but basically it is the same application.
Posted on: 17 October 2015 by Kiwi cat
DQ I run in-wall Paradigm speakers in my home theatre and they sound good in that application.
Posted on: 17 October 2015 by Mike-B
KEF have some nice "in wall" speakers.
Posted on: 17 October 2015 by feeling_zen
PMC Wafer
Without a doubt.
Posted on: 17 October 2015 by Huge
For the cabinetry, try investigating folded horn designs.
These may allow you a bit more flexibility and could potentially solve some of the problems that downward firing mid and HF units will otherwise cause.
Posted on: 18 October 2015 by DQ
Huge
Any particular company? I have been looking and not finding anything that looks quite right.
Posted on: 18 October 2015 by DavidDever
Directionality will be the biggest issue - to that end, the KEF Uni-Q based Ci200Q models (one square mount, one circular mount) would be quite good.
Once you get beyond a coaxial design, you have to consider phase & timing issues that may not easily be changed after the drivers are mounted.
Posted on: 18 October 2015 by Huge
Originally Posted by DQ:
Huge
I assume the cabinetry will be custom ddsigned for the application rather than just sticking a couple of 'ceiling' speakers into a flat pack cabinet.
If you're just putting speakers into a normal bit of furniture then it doesn't matter that much what you use: Unless you use really cheap drive units, the cabinet(s) will be the limiting factor in the SQ.
On the other hand to do it properly will require quite a lot of calculation (and take advice from the people who supply DIY kits for speakers).  There are designs for DIY horn speaker enclosures that can be used as the basis for a reasonably competent design that will control the directionality of the sound and give a reasonably even frequency distribution of both the direct and the reverberant sound.
David,
The original post specified downward firing drive units; I'd be concerned with the KEF concentric system that the MF & HF would be unevenly absorbed and reflected by both the void under the cabinet and the material of the floor.
IT may be possible to use a downward firing bass mid unit (with a low crossover frequency) combined with a forward facing tweeter, and to run the bass mid in compression driver mode.  To do this requires that there is only a small clearance between the bottom of the cabinet and the floor and there's a rigid reflective surface below the speaker drive unit.  This results in an effectively annular cavity coupled driver.
Posted on: 18 October 2015 by Innocent Bystander
If the cabinetry is solid, and large enough, and effectively a wall, you have the potential for very good speakers as rear reflections are eliminated - however from your mention of downward firing that sounds more like an overhead cabinet? To avoid losing the treble that may need a ceiling design for mid and high frequencies at least, with for example a conical reflector, or could you use smallish satellites below the horizontal surface and have bass speakers built into the cabinetry above?
Posted on: 19 October 2015 by DQ
Many thanks to all for the replies. Here is a little more detail to see if it changes anything.....we will have a line of cabinetry over a king size bed . It will be quite a wide run about 10 ft in total. The bottom of the cabinetry will be about 8ft off the floor (thus about 6.5ft off the bed) and the speakers would fire downwards onto the bed. There would be soft material on the wall behind the bed.
Given this I am inclined to thing that the top option would be the PMC Wafer 2 and 2nd option would be the Kef square Uni Q line
Any additional thoughts?
Posted on: 19 October 2015 by Huge
It would have been a good idea to explain what you were actually trying to achieve in your first post.
You've also now introduce the fact that this will be a near field listening situation.
You've still not specified how wide the listening zone is (1 person centrally or two people on the bed).
You've not specified the size of the cabinetry (top to bottom and depth from the wall).
All these affect choices.
