Is 252 a fully balanced preamp?
Posted by: Zeny on 22 October 2015
As the title says, is the 252 a fully balanced preamp from input to output? Fully balanced means essentially two preamps in one. The reason why i am asking is i have two other 2 box preamps of other make and both of them are fully balanced so it makes me wonder whether 252 is also designed as such
Posted on: 22 October 2015 by karlosTT
No, it isn't
Posted on: 22 October 2015 by Zeny
Thanks karlos
Posted on: 23 October 2015 by ianrobertm
Two pre amps in one box is dual mono. Which may, or may not be balanced.
AFAIK, the 52 and its derivatives are all dual mono - so 52, 82, 252, 282 & 552. Whether something is 'balanced' in audio terms, depends in its earthing, not on its circuit layout - AFAIK.
https://en.wikipedia.org/wiki/Balanced_line
https://en.wikipedia.org/wiki/Balanced_audio
Posted on: 23 October 2015 by Zeny
Thanks ian
i thought fully balanced and dual mono are the same but as you said they are different. If 252 is dual mono, is it fully balanced then?
Posted on: 23 October 2015 by David Hendon
No, dual mono and balanced isn't the same at all.
Dual mono refers to two separate and unrelated signals, for example two mono microphone outputs from different locations.  Stereo is two microphone outputs at the same location. I don't think you should refer to an amplifier as being dual mono although in the sense that the left and right hand channels are handled separately, all stereo amplifiers are dual mono as well.
Balanced/unbalanced refers to how the signal at the input or output on each channel is referenced to earth.  You could think of this as meaning that in the balanced case on each channel the signal on one wire goes positive from earth while at the same time the signal on the other wire goes negative to earth.  In the unbalanced case on each channel one wire is earth and the other carries a signal which goes both positive or negative from earth.  Balanced connections are usually used where there is a need to exclude heavy interference, for example on a long cable run.
In any case, as has been said already, the 252 isn't a balanced amplifier.
Best
