Seeking work around for connecting muso and naim app
Posted by: Daan on 23 October 2015
hi all,
Just wondering if anyone here has a solution for the following problem I encountered when trying to set up a Mu-so at the office. After connecting the Mu-so to the employee wifi network using key sharing, the Mu-so light turned white and iRadio worked if operated by the dial on top of the Mu-so. So far so good. Yet, the Naim app could not find the Mu-so. After spending an hour or so trying to fix it by manually adding a "room", using the ip address to be used for set-up using a pc and fruitlessly trying other potential work arounds, I called our firm's tech support. Turned out that for security reasons the office wifi network does not allow devices using the network to find each other and connect. Is there anyway I can connect the Naim app to the Mu-so by other means than using the same network?
If not, I would think Naim should consider to develop one, as there are presumably many more companies with similar security induced limitations in the wifi network and as a consequence Naim may now be missing out on what might be an interesting part of the market: people who like me like to listen to music at work.
thoughts anyone?
best, Daan
