Shippinf weights NAP 300 and PS please?
Posted by: Tarquin Maynard - Portly on 25 October 2015
Per title if you would.
TIA
Mike
If the boxes are white with a green stripe, it's marked on them. Older boxes, then email Naim.
Chris
En Angleterre c'est Dimanche soir. Naim ne travaille pas les Dimanches and I have to post some kit.
I need to order postage tonight so the Forum is the place.
According to the website the 300 shipping weight is 12.6 kg, they don't give the shipping weight for the 300ps.
Looking in the manual the actual weights are 10.7 and 14.1kg so you can probably estimate the PS as being between 16 and 17kgs.
Richard
My old 'Bible' gives: -
NAP 300 12.75 Kg
300PS 17.15Kg
Hope that helps - and is still accurate.
No good reason why it wouldn't be. Any other questions while I have it open?
Mike,
Stick them on the bathroom scales and if they come within Adam's figures ± 1kg, then go with 13kg and 17.5kg.
What is moving in to replace them ?
Don
Thanks chaps
Don old bean - if you'e free tomorrow around late am / lunchtime I'll phone you.
Be good to catch up
Mike
Thanks chaps
Be good to catch up
Mike
I'll be teaching tomorrow, but should be on the ground between 13:00 and 14:00
Same old mobile number. If I don't answer, send me a text rather than a voice mail and i'll get back to you.
Don
