Nap 250 DR
Posted by: Pawson6844 on 01 November 2015
You can ask Naim for that, but if you are unsure about a specific unit, it will have the DR logo on the back panel (if newly manufactured as DR).
If it was upgraded to DR, Naim can confirm that for you from the SN.
From what I have seen, units upgraded to DR also have the DR logo on the back.
It's your choice. If half price is £1,750 and you add the £1,000 upgrade, that's £2,750. Which is £750 less than a new DR version. Against that, maybe - and it's just maybe - an 'original' DR may - and it's just may - hold its value better. But if you don't plan to sell it it won't matter. But then again, do you want to be without your new amp for a month when you sent it to Salisbury to be upgraded? Like I said, it's your choice.
If 6 months old it is basically new but just run in nicely for you.
I would buy the 250.2.
Unless you are getting a 200 DR.
Then i would get the 250.2 without any hesitation.
750 GBP is a lot of money to save. and if and when you decide to go for DR upgrade, then it will be even better.
