Chord Hugo TT & Naim poweramp combo
Posted by: Ben Williams on 02 November 2015
I'm curious about using the Hugo TT as a preamp in combination with a Naim power amp, possibly a NAP 250.
I currently have a Supernait 2 & Hicap DR and was considering an upgrade to separates, most likely a NAC 282 & NAP 250 but is there any reason I can't just do away with the preamp and remove a whole box from the equation?
Chord constantly talk about how good their DAC's sound when used straight into a poweramp, how feasible is this is with Naim and is it a good match?
Would love to hear from anyone who has this or has explored this as an option.
Posted on: 02 November 2015 by Richard Dane
Ben please see my answer on this current thread...
https://forums.naimaudio.com/topic/chord-hugo-tt-dac
In short, it's not a good idea to use Naim amps without Naim pre-amps.
Posted on: 02 November 2015 by Allan Probin
For assessing the quality of the TT as a pre-amp, you could give this a try yourself using an appropriate cable to connect the output from the TT directly into the power amp section of your Supernait, by-passing the Supernait's pre entirely. If you felt it wasn't as good as with the Supernait pre-amp and hicap in circuit then it will probably be even further behind compared to using a 282.
You would need an RCA to 4pin DIN cable. Should be able to get something suitable and cheap from Flashback Sales or similar and I think I've seen these sort of cables from Chord crop up occasionally on eBay.
Posted on: 02 November 2015 by is that so
I am using the Hugo TT straight into the nap 250.2. It sounds great.  My Harbeths are really singing.
Posted on: 02 November 2015 by Innocent Bystander
Same as my experience of Hugo into Musical Fidelity P270 power amp.
i'm interested in Richard's caution against using a preamp, as at the end of the day, without going into the electronics, a power amp is simply something that takes an input signal and effectivey "magnifies" it to be large enough to drive a speaker. PROVIDED THAT the source device, if not a preamp, doesn't present too large a signal e.g. at first turn on, then I can't see the difference. Perhaps Richard would care to elucidate, unless it is just that concern that a signal might be too high when turned on.
Hugo has a built in volume control, but when first turned on doesn't default to zero, which is normal good practice, so I was concerned before first trying it myself. I therefore took care to turn on Hugo first and take it down to zero before turning on the power amp, whereupon I found that the default start level was not far off right - though I have always turned on components starting at source and working through in order, which avoids any switch-on 'thump' damaging anything, should any device create one.
i should have read the other post before asking Richard to elucidate, as I see it is to do with possible excessive bandwidth, which Richard says should be limited to 40khz, presumably Naim preamps doing that limiting.
Posted on: 02 November 2015 by Simon-in-Suffolk
I connected my Hugo into my 250.2 by bypassing the preamp stage, however although it sounded good, it was not a patch compared to the Hugo going actively to my 250.2 via my 252. I also use ATC speakers. Clearly if you were short of funds you could start by bypassing the NAC, but I would get a quality Naim NAC to go with the NAP when you can.. It will make a significant performance enhancement.
Simon
Posted on: 03 November 2015 by Briz Vegas
This rule seems to be broadly applicable.  I suspect it is because power amps are designed to be driven by a preamp.  Devices that are designed to go directly to the power amp almost do this as an afterthought it would appear.
Example from another brand.  Conrad Johnson CA200 is a 6.5K 300 watt power amp with a passive attenuator chip as a volume control ( they call it a control amp).   Run as an integrated it sounded very nice, bypass the amps attenuator chip and running a good digital volume control by Weiss directly sounded better.  But, add a 7.5K Conrad Johnson preamp ( with fully discrete attenuator, not some chip) and it walked all over the digital volume control solution.  Moving on to a big tube amp with fancy components ( Teflon caps) only emphasised this more.  Pre- amps give a power amp exactly the type of signal that they require. Multi tasking devices with typically weak ( by comparison) output stages do not do the job to the same quality.
At the end off the day hifi is about maximising quality.
Posted on: 03 November 2015 by Innocent Bystander
Agreed - and in my case SQ was better without a preamp (I was running through preamp before trying without)
Posted on: 03 November 2015 by dayjay
I ran a Hugo into a Nap100 and it worked pretty well although getting up every two minutes to change volume was irritating.  I also tried it into my SN2 by passing the built in pre amp and it was a step backwards compared to running it into the SN2 pre.
Never having had the luxury of a remote volume control before, I don't miss it!  I must admit, however, that there now seems to be more variation in volume levels between albums, and with being able to pick a new album without getting up it would be handy to be able to adjust the volume at the same time...
Posted on: 03 November 2015 by T38.45
years ago, I run a Klimax Pre with an NAP180...it was not that bad.....
