Newbie 42/110 Combo- Some basic questions
Posted by: Toolonginexile on 03 November 2015
Hello All
A friend has just asked me to take a look at his old 42/110 combo. Probably in contemplation of a sale. Now I am curious since I have never heard a naim product although i recall seeing a lot of sales of this combo with the Linn Kans as the "go to:" system when I was a younger audiophile.
Now im curious if i would make an offer on the pair to him. Or as they say whether its worth it.
Anyway I have done a search and read here about this combo but was wondering if those more experienced with the naim family can answer some basic questions.
1) Is the consensus that the 110 is a "better" product then the 42? If so how can you determine if this unit is a 42 or 42.5- which I understand to be a bit more advanced?
2) Is the default recommendation still to sell the 42 and move the funds towards a more upscale naim pre amp?
2(a) Am i correct that the 42 as opposed to the 42.5 cannot be upgraded and/or improved with a a new power supply?
3) If the 110 and or 42 is not in proper working order is it cost effective (in the states) to refurb/repair. I see one authorized repair center but the prices are definitely on the high side-which is ok for quality work. The question for the forum is whether this combo represents a value
worth the cost of repair. Obviously this will hinge on what work needs to be done, but assuming if they are not working its the standard cap/resistor type replacement for older solid state units. (Im a tube guy)
4) CABLES : While my friend did have a pair of linn kans for me to listen to, he did not have any DIN interconnect or speaker cables for the naim combo. I understand that naim prefers their own (or chord) cables for long term reliability and safe optimal operational points but is there "budget" cable to at least test out this combo? Frankly, I dont want to spend $100-300 USD on a cable just to test out .....
Thank you in advance for any assistance....as a die hard tube ls35a guy Ive always wondered what a naim sounds like and hoping this may be a cost effective opportunity to try it our at home or own a set.-albeit an "entry level" kit.
