Tonearm Cable with Stageline N
Posted by: marcobb on 05 November 2015
Hi Folks,
Could kindly advise on the tonearm cable with Stageline-N ?
Primary listen the Pop and Vocal.
marcobb
marcobb,
It would help to know the details of your vinyl system. Mine are in my profile and include a Stageline N.
I replaced the tonearm cables on my RP6 (due to a broken cartridge clip) with Cardas Litz wire. It's an economical choice and to my ears was not decidedly different from the original Rega cables. The advantage of the re-wiring was the Cardas cartridge tabs, a clothes-pin-like connector that makes for a much easier link to the cartridge terminals. The Cardas cable and RCA connectors also seem high quality for the price. I sent my arm to the cable installer and the price was ~$150.
marcobb,
Joerand,
Thanks for your information.
Maybe my mistake, it should phono cable.
marcobb
