Do Sonos integrate Spotify well?
Posted by: Sloop John B on 06 November 2015
I'm thinking of buying a Sonos connect for a friend who is retiring.
I don't think he has any ripped music nor is he likely to bother ripping.
I'm hoping that Sonos has integrated Spotify  in such a way that he will think he has the mother of all collections when he opens the sonos app on his iPAD.
Is this the case, the internet searching I have done  does not make this entirely clear.
Posted on: 06 November 2015 by Andrew Porter
Extremely well, as is Tidal. The search function via Sonos is quick and pretty awesome!
Posted on: 06 November 2015 by ChrisH
Its very user friendly and does streaming services really well, you can't go wrong for your friend with this SJB.
The Sonos app is probably also the benchmark that others aspire to, extremely intuitive.
Posted on: 06 November 2015 by Hook
Hi Sloop -
It also works very well with Music Vault and Deezer Elite (lossless - US only). One search, and I see all matches in my UPnP library as well as in both services.
The Sonos Connect is very affordable, easy to set up and use via an iPad app, and as a digital input for my NDS, the sound quality is more than acceptable to my ears.
ATB.
Hook
Posted on: 06 November 2015 by mackb3
SONOS integrates better than anything at the moment. Radio, Spotify,  Deezer, TIDAL etc... into a Naim ND streamer or DAC and all is good. Fear not and proceed with a Connect.
It's good to be King.
Posted on: 07 November 2015 by Simon-in-Suffolk
Agree with comments above.. Also Sonos integrates well with local media on a hard drive or NAS, and supports UPnP media servers.. All from the same control app.... the only thing the Sonos control app doesn't do is my Naim volume control automation
