NS-O1
Posted by: WAYNE DAVIES on 07 November 2015
about two years ago I upgraded from a unity serve to NS-01,because the unity serve caused nothing but problems. Since upgrading the problems have intensified. first issue was a bad disk, next was a total shutdown and now all the techs from the dealer can't help. Naim will replace the unit or give me a NDX. If I accept the NDX I need a NAS which I really didn't want in the first place. What would be the best choice.
Posted on: 07 November 2015 by Harty601
I was going to buy a unitiserve as I was nervous about setting up a NAS with my limited IT knowledge. However, I went for a Qnap NAS and with a bit of research and help from the guys here, I got it up and running and it's been Bullitt proof and I saved about £2k in the process.
I would go for an NDX and buy a NAS, although what have you been using to stream the media off your NS01?
Posted on: 07 November 2015 by hungryhalibut
Take the NDX, which is really good. Then get a Synology or QNAP nas, install Minim or Asset and off you go. If I can cope with a nas and a streamer, anyone can.
Posted on: 07 November 2015 by nickpeacock
Ah, it looks like the NS-01 has its own internal storage drive (like an HDX). The NS series doesn't get much press on the forum; I wonder how much future there is in NaimNet. You might look at an HDX but, again, it doesn't seem to fit with Naim's future thinking (an admittedly opaque concept).
Anyway, lots of people on the forum will be very happy to help you with an NDX/Nas setup. (I use a Synology and use the Media Server software which comes with it.) It'll be more hassle in terms of ripping CDs but, once you get used to it, considerably more flexible.
Posted on: 08 November 2015 by John Bailey
Have you been using the NS01 as a server (to say a streamer) or as a player (using the digital or analogue output)?
In general the NS01 should be pretty reliable - the HDX is basically an NS01 with baubles on and (in general) seems pretty reliable. I don't see why Naim can't sort it out for you.
If you keep it you will retain the convenience and performance of an excellent ripper but lose the flexibility in playback that the NDX provides - streaming services, HLS radio streams, dac inputs.
What would you choose if you were starting from scratch? Reliability aside is the NS01 still the best fit for your requirements? Would the HDX provide a better one box solution if you could get one of those?
Posted on: 08 November 2015 by sktn77a
Hard drives have a finite lifespan and the ones in the HDX/NS01/NS02/NS03 will die eventually.  Its not just a case of swapping out the drives - the units have to be sent back to NAIM or an authorized and qualified service center as the OS is located on the main drive.  Go with the NAS setup and either an SSD HDX or NDX to future proof your investment..
Posted on: 08 November 2015 by Claus-Thoegersen
Why do people think ssd is the answer to everything. Ssd fails. Just because they use ram chip instead does not at all make them safer.
Since Naim is very  silent about what if any Development will happenwith the servers, and the streamers on the other hand are very actively in Development, should I replace my ns01 today I would probably go for an ndx, or a streamer from another Company to be used with my ndac.
Claus
And one more thing. I bought my ns01 in June 2011, and the cd drive died in august 2014.
I bought a Readynas Duo v2 in the summer of 2012. A few months ago I began to get warnings from the firmware on the nas about damaged sectors from the nas.
So I bought a 3 tb drive optiminzed to be used in a nas.
So both systems have failed, but since I can replace the disk in the nas without sending it to Naim the Price for a nas feilure is much lower.
Claus
Posted on: 08 November 2015 by WAYNE DAVIES
Thanks everyone for your comments, they were helpful. I have decided to take the streamer. My dealer will now deliver a NDS and will deliver it to my home and set up the NAS. he also suggests that I disconnect  the 555ps from the dac and connect it to the NDS. IS this a good idea?
Posted on: 09 November 2015 by hungryhalibut
Do you mean NDS? If so, it needs the power supply to be able to work.
Posted on: 09 November 2015 by Bert Schurink
+1 it's simple, easy and stable.
Posted on: 09 November 2015 by Hook
As HH says, the NDS has no internal PS, so it will need your 555PS in order to work.
The NDS has digital inputs, so unless you have a lot of digital sources, you will no longer need your Naim DAC. The NDS/555PS is a replacement for your NS01->DAC/555PS.
Good luck!
Hook
Posted on: 09 November 2015 by Jan-Erik Nordoen
Most definitely !
Originally Posted by Hook:
> The NDS has digital inputs <
Disconnecting the unused ones (through the Naim app) is recommended as a way of slightly lifting performance. It also makes navigating sources easier as fewer *source* icons are presented on the app.
