'source first'
Posted by: sharik on 08 November 2015
- so true indeed... recently i purchased a MacBook Pro Retina to replace the Oppo 105 in my system; the sound has improved considerably (provided, the Mac is powered with internal batteries while not connected to the power circuit) even without use of an external DAC, that is, Macbook plugged directly in the integrated amp (Supernait 2 in this case) with a mini-jack/RCA through DIN5 adaptor interconnect bundle; hey, is it some kind of synergy between MacBook Pros and Naims?
Well, an Oppo 105 just isn't in the same league as a SN2, so think what a decent DAC will do.
Improving the source in a mullet is definitely going to work!
The Macbook pro is a great platform for playing music and it goes very well with a naim system.
Now that's an unbalanced system!
Wow, I find this intriguing my MacBook Pro Retina has a shocking audio output.. It's noisy and unrefined.. There is a distracting amount of low level high frequency RFI noise as well... as many know the shielding in laptops is typically rather poor and not recommended for use on your lap unless wearing shielded boxer shorts!! MacBooks and direct audio replay I like to keep well seperate. If you need quality audio, then couple to a remote DAC by USB or Ethernet.
Put a Hugo in between them and run Audirvana on the Mac and then it really starts to sound good
Yeah, me too. Intriguing and baffling. I can't imagine that the DAC in a notebook comes close to being a decent source.
and i do use a DAC, currently Nad M51 that i already had, but mostly for the reason i'm reluctant to go into trying figure out which mini-jack/RCA/DIN5 cable is best for direct connection to the amp.
Yup, gotta protect your little swimmers.
- rather strange because by many accounts the MacBook Pro is deemed to have a very decent sound.
I guess it all comes down to what you're comparing against and what your expectations are; certainly I find my 2 year old MBP's headphone audio is improved no end by adding the neat little Dragonfly USB DAC. This makes it a pleasant device to use for headphone listening while moderating the forum. With the Dragonfly in the bag (or something similar), it positively encourages me to listen to music while I'm working or moderating the forum. Without the Dragonfly I'm not so keen and don't bother...
So if we can kidnap the Dragonfly, we can have endless fun offering things for sale, discussing fuses in an obsessive way and mentioning certain companies that must not be mentioned....... Anarchy is just a Dragonfly away !
ahem...
...without the Dragonfly I can't be bothered listening to music on the MBP...
And yes I also use the Dragonfly USB DAC on my MBP and other than lack of granularity on suitable volume level on sensitive IEMs is a huge step forward to the MBP inbuilt audio output....
for example a symphony orchestra or opera house kept in mind when changes made to the system.
I use a Halide HD DAC cable off my MBP and run Audirvana Plus into my 552. It sounds pretty good, but not the equal of a Naim CDP such as CDS2 or CD555. Based on what I have heard on my son's UQ2, I think that UPnP would sound better if you could make that happen.
ahem...
Sounds like you fine gentlemen need a V1 ![]()
Hmm but the V1 is not the size of a USB memory stick...
Yup, fine though the DAC-V1 undoubtedly is, it's not a portable option. The Dragonfly is not the last word in SQ by any means, but it does markedly improve the MBP headphone out, is more than good enough to be enjoyable to listen to, and it's form and size are ideal for the task.
Oh, and it has a picture of a dragonfly on it that lights up and changes colour depending on what sample rate you're using - what more could you want?
Perhaps a Mojo
A portable Statement? ![]()
Very true.
lol you make a good point.
maybe an OS installed on the MBP is what makes the difference?
