Posting Album Covers from iPad?
Posted by: GraemeH on 09 November 2015
I go away for a week and come back to find I can no longer easily post album covers via google image from my iPad.
Anyone with the same issue and is their a work around?
Thanks,
Posted on: 09 November 2015 by dayjay
I didn't know you could Graeme, thought you had to line to photobucket or another host which is why I never bother posting the cover
Posted on: 09 November 2015 by sjbabbey
I'm having the same problem (had to use firefox on my upstairs PC to post my last one). I've seen a suggestion that you long tap an image and get it to open in a separate tab and get its URL from there but I couldn't get that to work either.
Would also like to hear of any easy solution or work around.
Posted on: 09 November 2015 by osprey
I use Bing nowadays to get the URL of an image.
Posted on: 09 November 2015 by Steve J
If a 'normal' URL doesn't work I can usually find the album on Wiki. Simply open the pic/Details/copy link. Usually works well.
I used it yesterday. Will give it another go.
Posted on: 09 November 2015 by GraemeH
Scrub that Steve - Your suggestion does indeed work.
Thanks,
Aha, yes indeed it does!  thanks Steve
You're most welcome chaps.
