Speaker Advice
Posted by: Music Man on 11 November 2015
Hi,
I currently have a Systemdek IIX with a Month-3 arm & am having it fully serviced. Will replace the glass platter with a 10mm SRM acrylic one and intend to use a puck. Cartridge will be Ortofon Bronze (decided against Black due to cost & its probably OTT for the current deck).
Naim NAC-82, Hi-Cap
Naim NAP-250
Naim CDX-2
Epos-11 speakers and REL Strata II active sub.
I have a plan to replace the Systemdek with an LP-12 Ittok, Lingo so I'm hoping the front end will be as good as I need.
In the meantime, I think my speakers are the weak link here: I'm after a big 3D soundstage, but with plenty of detail - hence the Ortofon Bronze - I really liked its sound.
Can anyone advise what speakers might fit the bill? I have a preference for floor-standers now & will hopefully no longer need the REL to support the bottom-end.
Thanks!
