UQ2 + Nap100 speaker upgrade
Posted by: rainsoothe on 12 November 2015
Yea, so... Hi again.
Since my last visit, I ended up with UQ2 and Nap 100 with Flashbacksales RCA to Din interconnect, and DNM Reson speaker cable into my Focal Aria 906. Lemme start of by saying I love the sound, and it suits my 16 sq m living room beautifully (no bass bloom, which was a problem with other setups, beautiful soundstage etc)
Now, when I went to pick up the Nap100, I made the mistake of auditioning ma Nac-N 172 + Nap 155xs into Revel Performa F206. Needless to say, it sounded amazing.
I was thinking of the Revel standmounters, the M105, but sadly I can't audition those. I also got a recommendation for Wharfedale Jade 3.
My question is has anyone compared or at least heard both the Wharfedale Jade 3 and Focal Aria 906? Would it be an upgrade or just a sidestep?
Also, would a pair of Revel Performa 3 m105 be a good fit in my setup? Same question for anyone who's tried XTZ Master 2.
The sound I'm after is not overly detailed but coherent and musical, neutral to warmish, big soundstage that makes the speakers dissappear completely, tight low end that doesn't boom and makes walls shake, and no "cupped hands on voice" effect. So I guess almost just like my Focals, but a bit tighter, less airy and that brings music in the centre of the room.
Oh, and important: big sweet spot, as in good off-axis listening. I dont want them to sound good only in a 1mm spot.
Thank you and muchluv
