No BT on Uniti 2 since 4.4 update
Posted by: spurrier sucks on 15 November 2015
as the title says I can't get my iPad or iPhone to pair with my U2 since I've done the latest update. Anyone else have this problem?
Posted on: 15 November 2015 by Mike-B
So what have you done or tried to get it to discover the system ???
Its worked OK for everyone else so it has to be something basic you have not done
Is it connected with ethernet or wireless
I suggest to reboot it all,  (turn it all off & back on),   in the following order,  but leave the BT hub turned off for 5 mins before restarting
Start the BT router & let it complete its full start process
Start the NAS or whatever else you store music on & let that complete its full start cycle
Turn on the Uniti & make sure it can see its network (NAS or music store)
Turn on the iPad
If that doesn't work,  come back
Posted on: 15 November 2015 by ChrisSU
Mike, I think he means Bluetooth, not British Telecom! Although 'turn it off, turn it on again' is always worth a try...
U might be right Chris,  in fact reading it again I now see the "paired" word so you are more than likely spot on right.    oh well maybe a reboot will fix it anyhow.
Posted on: 16 November 2015 by David Hendon
I don't think anyone else has reported this problem.  Have you reset the U2 to the manufacturers settings after the firmware update? Also check in the U2 settings that BT is enabled. Assuming it is, I would then try pairing your iPhone or iPad from scratch, ie delete the old pairing and re-pair as you did the first time.
i hope this helps.
Posted on: 16 November 2015 by spurrier sucks
Thanks for the responses. I am referring to Bluetooth. I powered down my U2 and powered on, tried to pair again but no go. I looked for a setting in the menu to turn a at on but I do not see one. When I try to pair the message I get cannot connect make sure Uniti is on and in range.
Posted on: 16 November 2015 by ChrisSU
Have you tried looking in the iPhone's Bluetooth settings. If your U2 is stored there (with its old firmware) tell the iPhone to 'forget' it, then restart everything and try pairing them again. I can't promise this will work, but worth a try if you haven't already.
That worked! Thanks for the help!
