Hi, Why does i Pod connection work on front of 5i work OK but not with i-phone ?
Posted on: 24 November 2015 by Stoik
Because it's a smart phone and won't let you spoil your Naim with Justin Bieber's latest hit.
Sorry, the door was wide opened.
Sometimes a protective case on the phone could cause the audio plug to not being inserted completely, but it's give the feel it is. So double check this, along with the audio volume adjustment on the phone.
Bye.
Posted on: 24 November 2015 by melvinolotus
Brilliant !!!!!!!! took case off .works a treat.......Many thanks, easy when you know how, Cheers....MEL
