Does the Naim app support the iPad Pro?
Posted by: Jota on 24 November 2015
As in the title.  Will the app work well on an iPad Pro sized screen?
Edit, it does.
Posted on: 26 November 2015 by Wazza69
Does it have any benefits (ie displays more) or it stretched?
Posted on: 26 November 2015 by TJ
Hi Jota,
Currently the Naim app will scale on the iPad pro. So you will get exactly the same UI as on the iPad but it will scale to fill the entire iPad pro screen. We are currently working on the app to dynamically resize when running on the iPad pro so it will make better use of the screen space. This should be available in our next public update
Posted on: 26 November 2015 by Jota
It's not stretched Wazz.  Looks like it looks on the iPad Air.
TJ, that's good news.
Posted on: 24 December 2015 by Silence Kills
Hi TJ,
thanks a lot for the update. Do you have any idea, when (date?) the Naim App will be ready for the iPad Pro? I don't want to buy the iPad Pro before the Naim App is natively supported ;-)
Posted on: 26 December 2015 by Harty601
I got an iPad pro a month or so back. The naim app works well and looks great on the bigger screen - although an update to take advantage of the pro size will be nice.
The apple pencil is fantastic, and I'm very impressed with the keyboard on the smart case - not that either are relevant to running the nail app ��
