Have SN2, getting the NDX or go for the 272/250DR?
Posted by: kaydee6 on 30 November 2015
Hi,
I need some advice.
I have a SN2 and getting a NDX soon. At the same time, dealer offer to trade the SN2 for a 272+250DR with top up.
Should I go for it or stick with the NDX+SN2?
I have the impression that the NDX better the 272 or am I wrong about this?
Thanks in advance!
Posted on: 30 November 2015 by ChrisSU
My choice would be NDX, but presumably, your dealer will let you listen and decide for yourself. I thought the 272 really needed an XPS to make it sing, but then there are 3-box options with the NDX that I'd take in preference.
Posted on: 30 November 2015 by kaydee6
Thanks Chris, I am leaning towards the NDX. One reason is if Naim does update their nDAC, I can upgrade the NDX with it. Can't do that with the 272.
Posted on: 30 November 2015 by Patu
Still haven't auditioned 272 + 250.2 DR at home, will do so soon. But I've asked for an offer to switch from my current setup (DC1 digital cable - nDAC - SN2 + HCDR) and the amount of cash you have to throw in for the switch is so big that it really should outperform nDAC + SN by a huge margin to justify the change. I have some doubts it'll be that much better but you can only tell by comparing the two setups. I know my speakers would benefit from some extra power but then again I'm not sure if 272 betters Naim DAC as a source.
Posted on: 30 November 2015 by Jan-Erik Nordoen
Precisely. The nDAC with its current FW and without external PSU is superior to the DAC in the 272, IMHO. Also the the SN2 preamp and the 272 preamp are pretty much equivalent.
Posted on: 30 November 2015 by Harty601
I ran an NDX & Supernait (1) along with a 272 & 250 (non DR) on home demo for a week (side by side). I went for the 272 with a 250DR as I felt the 272 had a wider sound stage than the NDX and the 250 (especially the DR that I bought) had more control over my Spendor A9s.
I'm trying out an XPS on the 272 currently, and it does a nice job but it hasn't left me feeling that the bare 272 is lacking for now.
I have no experience of the nDac so can't comment on what that does for the NDX and as you point out, it is not applicable to the 272 (which will be a draw back for some).
I was hesitant to go for a pre amp and source in the same box, but in the end I let my ears make the decision and 2 months in I am very happy the 250DR just seems to get better and better.
Well SN1 really shouldn't have anything against 272 + 250.2 DR, no matter what source you use. SN2 is on completely different level compared to its predecessor. But then again, SN2 probably clearly fells short compared to 250.2 DR.
Hi Patu, have you heard the big difference for yourself between the SN1 & 2 - I only ask as I never heard the SN2 - my dealer advised the difference between SN1 & 2 was not worth the money it would have cost to change to the updated SN.
Posted on: 30 November 2015 by hungryhalibut
I chose the 272/250 over the NDX/SN2 for reasons of logistics: maxed out with one power supply rather than two, no expensive interconnect required and only two mains leads in the maxed out setup. Added to that the 272 has a far nicer volume control, and doesn't have loads of inputs you'll never use. The 250DR is also far better than the power amp of the SN2. But as for which sounds best, I don't know.
Yes, I come from SN1. It was my first touch to Naim and I used to run it as a one box solution. First I upgraded it with HiCap, then with Naim DAC, then changed HiCap to HiCap DR and the latest update was SN1 to SN2 right after the SN2 was released. It really is completely different amplifier. Out of those updates I've made, SN1 to SN2 is easily the biggest one. The difference was even bigger than changing from SN1's integrated DAC to Naim DAC. SN1 sounds muffled, slow and generally lesser amp compared to SN2 which has way better grip, more authority and better resolution compared to SN1.
Why wouldn't you need good interconnect cable with 272 + 250.2 DR just as much as you do with NDX + SN2?
Posted on: 30 November 2015 by Mike-B
I agree,  not worth the price of an exchange.  Yes its a really good amp,  but so is the SN(1).
I found the difference is marginally better with the SN2 in some respects,  but in some areas I preferred the SN(1)
The other things for me is the lose of the buffered record button bank which I use to drive my 2nd system,  & although not the best,  I use the DAC for AV input.
My next move (if I was changing the amp) would be 282/250 & keep the NDX - I preferred that combo over 272/250,  but so it should be if you take the cost as an SQ guideline,  but it did tell me the 272 is damn good VFM
Thanks Patu, that's very interesting. I found a big jump in SQ when I put a Hicap on my SN 1 - I enjoyed it very much for 6 or 7 years with a bare CDX2.
Yes, HiCap was a clear step up with SN1. I'm not even sure how big of a step up it is with SN2 since I've had it plugged in since I bought SN2 and never auditioned it without HCDR. Many have said that it's not as obvious step up as it was with SN1.
But as you can see, opinions differ. I respect Mike-B's but to me it really is the best upgrade and biggest performance jump I've made with Naim. By no means is the difference small between SN1 and SN2. Definitely worth auditioning the SN2 by yourself.
  I expect we need to take speaker load into consideration as we are not comparing apples & apples. I've designed my speakers to be a relatively easy load with some impedance compensation. However they go down to 2.7 ohms in the bass resonance region & is between 3 & 5 ohms from 10kHz to 20k & it was in the treble region I was not happy with SN2.
When I made the change, I used PMC GB1i. Later I changed them to PMC Twenty.23 and now I drive ATC SCM40Mk2 with the SN2. ATC's are clearly more difficult load for the amp than PMC was but it still does good job with them.
Treble region is more lively and up front with SN2. When I first fired up my new SN2, I first thought that this is not what I want. First it sounded edgy and the treble was way too hot for my taste. SN1 had been so easy to listen to and somewhat soft with its presentation that SN2 was quite a shock. But this, like many other aspects in the sound, changed a lot during the burn in period. Later on the treble has never been a problem, not even with my most notorious treble/sibilance test tracks.
OK Patu,  I think we need to drop this as its drifting off the thread subject
Yes, sorry for going offtopic.
Mike, you had me at "impedance compensation"
Thanks to all for the advice. Made my decision and going to the dealer this week. Always exciting to buy new toys
Posted on: 30 November 2015 by totemphile
Jan, did you ever get around reviewing the 272? If so, is there a link to it somewhere?
MTIA
tp
Hi TP,
Yes. Summarized in bits here :
https://forums.naimaudio.com/to...-or-linn-akurate-dsm
Jan
Posted on: 02 December 2015 by totemphile
Thanks for your reply Jan - good read. I think I will hold on to the nDAC for now, especially with the new update available, which will hopefully give it yet another nudge up the scale.
Best
tp
Posted on: 02 December 2015 by kaydee6
Got the NDX last night. Hooked it up and the first impression is very positive. I think I got the Naim sound signature back but will do more listening when the unit warmed up somemore.
Updated to 4.4 and tried Tidal. I have to give it to Naim for the Tidal integration. UI is very smooth and slick.
I have used the following before getting the NDX:
Moon Streamer 180D
Chord 2 Qute dac
MF V90 dac
Tidal is delivered through Bubbleupnp before.
Now I like the Naim apps with NDX.
