snaps getting hot!
Posted by: Claw24 on 03 December 2015
I have aquired a snaps and just plugged it in to the mains (not connected up to amps yet before the avalanche of replies) and it became hot within a few minutes.
any suggestions?
Posted on: 03 December 2015 by Hodders
I had a similar experience with an old snaps I acquired a few years ago. I sent a picture of the inside to Class A in Sheffield and was informed something had burnt out. I had it repaired and serviced there to a very high standard and at a reasonable cost. Sorry for the lack of specific technical information, but I hope this helps.
Posted on: 03 December 2015 by Claw24
Many thanks Hodders!
I did think this was more than likely the outcome but just wanted to see if it was something that may be a simple fix
Posted on: 03 December 2015 by Richard Dane
Do you know its history? Either way, it's an elderly bit of kit so get it checked out by Naim or a Naim approved service agent.
