dac/flac update
Posted by: Paul Stephenson on 16 May 2011
http://www.naimaudio.com/news/article/3315
Posted on: 19 May 2011 by jmdx96
Hello,
Great job, it works perfectly with very high resolution files, WAV or FLAC.
Thanks a lot.
Jean-Marie
Posted on: 25 May 2011 by Congee
Hello, anybody knows how to select song number ? I just loaded 50+ flac. It would be painful when want to listen song number 40. Thanks.
Posted on: 25 May 2011 by pcstockton
Unfortunately I think your only option is to hit "Next" 39 times.
Posted on: 29 May 2011 by Congee
Can we ask for few functionalities on next firmware update, like :
1. random play
2. song number selection
3. select play order by number, date, filename, ....etc
All these feaures definitely will add funs when playing with USB stick.
Cheers !!
Posted on: 29 May 2011 by pcstockton
Congee,
How exactly would you propose to control #2 and #3?
-patrick
Hi Patrick,
Perhaps we can use some kinds of combination keys to control via remote, eg, tun+2, tun+3, etc.
Congee
Posted on: 05 June 2011 by GrahamFinch
Question for Paul please - does this also support flac from nas drive or other streamers? Is this the same update that we heard about a few weeks ago that seemed to be problematic for some users or is it another version??
Thanks Paul.
Posted on: 06 June 2011 by Paul Stephenson
Hi Graham, this is an update from the 1st release, with issues fixed.
Only USB flac.
