RIpping CDs into NAS using iTunes : metadata support
Posted by: Philippe CHESSEL on 09 December 2015
Hi,
As anyone experimented with music storage on a NAS with ITunes and managing the associated metadata ?
I have a Naim Unity device that i am happy with . I have recently added a Synology NAS system on my network. After the setup was done, everything was fine and i can use the Naim App on my iPhone to drive the Naim to read music from the NAS.
Then came the question of what options would i use to store my CDs and music on the NAS : WAV, FLAC or ALAC.
One pre-requisite is that i would like to keep the capability to synchronize some of the music on the NAS onto my iPhone or iPad, then keeping iTunes as the interface to the ripping (iTunes as a nice option to allow to copy music play list in chosen preferred format like .mp3 to save space on the phone.)
So i started to make some tests :
1. WAV. put CD tracks on the NAS as .WAV. Fine with iTunes, but the problem is that no metadata (cover, compositors, ...) is kept on the .wav file, it is kept and exposed only by the iTunes Library so then you lost lots of functionnality and metadata when using other interfaces like the Naim App for example.
2. FLAC : you can not encode CDs into FLAC format from iTunes from what i know (?)
3. ALAC. : Then ALAC was my only choice at then end. Encoding in ALAC from ITunes onto the NAS allows me to reach all of the metadata (artist, album, compositor, ...) as it looks that the information is then stored in the ALAC file itself.
A trick , that i still need to go through is that each time i import a CD as ALAC , i need to remove the cover added by default and reimport it from an image file .jpg. It looks like when you re-import the cover image it gets then really stored in the ALAC file itself so other apps like the Naim iPhone App can display the cover :-)
Regarding the sound quality , i don't see any difference between WAV, ALAC and FLAC as at the end of the day the ALAC or FLAC is decoded in the same digital stream as the original WAV. So i am a bit amazed that some people in the forum mention they hear difference between WAV and FLACor ALAC storage ?
Philippe
