Mu-so, problem using Airplay
Posted by: Patrik S on 13 December 2015
Hello all,
I have a serious problem with my Muso. From time to time the Muso does not show up (on my IPAD/IPHONE) as an airplay unit. The IPAD/IPHONE just doesn't seem to recognise the MUSO and the Muso does not show up in the list of available Airplay units. However this problem does not occur for other airplay units such as Apple TV. Muso then also loose contact with the Muso app ("rooms not found"). The wifi indicator on the Muso i still white which indicates that it has wifi connection. Sometimes I can "repair" the problem through running the installation procedure again (including restarting the router). The Muso then works through airplay for "a day or so", and then "connection is lost" again... I have a very fast (fiber) internet connection and the wifi signal is strong. Muso is also running the latest software version (to my knowledge). The Muso works fine with cable connection, and Bluetooth also works, but I really want to use the Airplay connection...
Is this a hardware problem (problem with the Muso iteself), or is it some other type of problem?
Many thanks in advance!
Patrik
