HDX play DSD over spdif
Posted by: Paul Quigley ie on 14 December 2015
Now the nDAC supports DSD files would it be possible to get the HDX to play DSD files over spdif to the nDAC?  Can the HDX hardware support this?
Thank
  Paul
Posted on: 14 December 2015 by ChrisSU
No, the Naim servers don't support DSD. I guess it would be nice if they did, although I can't say it bothers me much at the moment given the high price and limited choice of material available.
Posted on: 14 December 2015 by Simon-in-Suffolk
Although the servers don't support DSD at the moment, it should be simply a software change to send DSD via DoP over the SPDIF port or Ethernet for the DACs and network players.
Simon
Posted on: 15 December 2015 by robgr
In the meantime play DSD via USB on the DAC
Posted on: 15 December 2015 by Eloise
If you have dsd files on your computer; I understand it is possible to create a DoP file using dbPoweramp (and other applications).
For dbPoweramp you need to find (google) "dBpoweramp Codec Central: Direct Stream Digital (DSD)". I've read using Foobar 2000 SACD plugin to do the same - more instructions can be found by googling "How to use the Squeezebox Touch to play DSD files on a DoP compatible DAC".  (sorry I don't think I'm allowed to put actual links in?)
Once you have your DSD saved as DoP FLAC files the HDX should pass these through transparently to your Naim DAC (via SPDIF) though of course the HDX won't play them itself (you will get horrid noise quite likely).  The same method should work for enabling the HDX / UntiServe to supply DSD files to the (compatible) streamers.
No guarantees this will work ... but it should do ...
Posted on: 15 December 2015 by Jan-Erik Nordoen
Very interesting. Thanks Eloise !
Posted on: 15 December 2015 by Paul Quigley ie
Eloise Thank you.  That seams like a great solution. I will give it a go. Thanks for the help.
Paul
Simon-in-Suffolk posted:
Simon
Thanks. This is what I was thinking. I hope Naim will implement this software update.
