Hi cap position on Fraim shelf
Posted by: Pawson6844 on 29 December 2015
Hope you all had a good Xmas.
I have a question about my hicap. It's on the first shelf above the nap250dr which is on the base.
Its located on the very right hand side of the shelf with the napsc sharing the same shelf but on the very left edge so there is a gap in the middle.
I can't avoid the cables to and from the hicap touching the centre support of the Fraim at the back.
If I swap the hi cap and napsc over I can avoid all cables touching the Fraim.
Is this worth doing
Current layout top to bottom is
cd5xs
202
flatcap xs
napsc Hicap
250dr
Thanks Dan
