UQ2 and .m4a files won't play
Posted by: robert_h on 30 December 2015
Hi, I have a brand new unitiqute 2, and my music files are served up by jriver mediacenter running on linux. I'm not sure using jriver or linux is relevant per se, the OS shouldnt matter, and jriver creates a standard dlna server. I dont have issues with any other files, I can play back flacs of any resolution (16/44, 24/192 for example) either by streaming from jriver itself selecting the UQ2 as the device, or the other way around ie selecting files via upnp from the UQ2 itself.
Where I am getting stuck is with .m4a apple lossless files, they just wont play. I might get 1 second only, and the UQ2 complains it cannot play the stream, and jriver mc21 crashes. Doesnt matter if I send from jriver, or select via upnp from the UQ2 itself. Obviously I could convert everything to flac, but I believe alac files should work.
Is there a setting somewhere I might have missed? Otherwise I have no issues whatsoever, everything plays perfectly (apart from "shine on you crazy diamond" from a usb stick but I assume the file is too large for the UQ2 to load into memory as I'm playing it right now via upnp).
thanks, Robert
