HDMI Audio De-Embedder
Posted by: AndyF on 31 December 2015
Does anyone have any experience of HDMI audio de-embedders? My n-DAC has just had the software update so it now handles DSD files and therefore SACD. I have a new UnitiServe-SSD and in re-ripping all my cd's find I have a couple of dual layer discs including a SACD layer which the US won't touch. I also have a Sony BDP-S7200 Blu-Ray which will play SACD discs. The problem is the Sony only puts out the DSD quality signal to the HDMI output not the coaxial S/PDIF which I have connected to the n-DAC. Accordingly whether its a Blu-Ray or SACD, the HD LED on the front of the n-DAC remains unlit as it's only receiving standard definition audio. A google search brings up hdmi audio de-embedders which split the audio signal from the hdmi and output it to either a toslink or coaxial output which I could then connect to the n-DAC. I have no idea whether these work, are of good quality or even whether they might breach copyright.
Thanks.
