The pleasure of personally, manually caring for a thing of beauty (or, just don't be lazy about something you love)
Posted by: Massimo Bertola on 01 January 2016
Yesterday morning I decided to use the morning to finally rebuild my SBLs (mk2, cherry, 1997 vintage), bought from a German dealer in July 2014, my second pair in ten years. The left one opened up easily, like a mature clam, revealing an almost immaculate gasket; but the right one resisted, and I had to destroy the gasket to open it. Now, I proceeded to remove all traces of glue and rubber from the metal plate of the lower box, and this was by far the only boring part of the job. My advice to anyone doing this is to wet the stuff with alcohol, caring not to drop it inside the lower box, and use a spatula, with slow, 45° forward movements, to patiently remove them wiping the spatula's edge clean frequently.
Some pads had been pierced through to the wood, so I used a stick of wood repairing wax to fill the tiny scratches and holes; the pads themselves were occasional replacements, cut from a box of something I was not able to identify; the new ones, on the other hand, were original, brand new spare parts. While placing the new gaskets I could appreciate the complex construction of the lower box - the resonating chamber - and the 'filter' separating the two enclosures, the small radiator-like unit meant, I imagine, to 'break' and diffract the turbulence of the air emitted by the rear of the woofer, on the bottom of the middle box; and tried to imagine designing and producing something like this today.
With the silicone in place, I then carefully placed the middle box on the lower one, gently! pressing it down so that it came to rest on minimal, one-pointed cavities; and I immediately noticed how wider the new gap between lower and middle box now was. For sure, the trip from Stuttgart had caused the spikes to pierce the wood. Placing a circular spirit level on the top of the middle boxes, now in place, I saw that they were perfectly level. Adding the tweeter boxes is a child's play.
That SBLs, properly setup and sit, have a wonderful, balanced sound with a very natural presentation is a known fact; but I wanted to praise the thought behind them, the clever design, the smart use of the 'form follows function' principle. When you use your time, hands and patience to renovate a pair, you come to actually love them, and to want to have them in perfect conditions, always. Thanks, Mr Roy George, for these - and for the handful of other Naim designs you are a parent to, usually among the ones I like most (and thanks to Christopher, who stubbornly nailed it into my head to win laziness and finally do the job).
M.
Posted on: 01 January 2016 by Richard Dane
Well done Max.  I think we now need some pictures...
Posted on: 01 January 2016 by gary yeowell
Classic bit of kit, worthy of your time Max!
Posted on: 01 January 2016 by Massimo Bertola
I am a very lousy photographer, but sure, as soon as I am back home I'll do my best and post a few images. It could be the right occasion to finally learn to take decent pics. It's a gift, not only an acquired ability; and I don't have either..
M
Posted on: 01 January 2016 by Gianluigi Mazzorana
That's something i have to do since years and that i keep on postponing!
When about 10 years ago i got and put together mine i got pleasantly hit by their construction. Albeit only one year before i helped my friend to set up his pair.
I always considered SBLs more like an analogue musical instrument more than a simple loudspeaker....
And yes Max! We now want the pics!
Gianluigi Mazzorana posted:
Yes, that was somehow my feeling too; for sure, SBLs respond as pleasantly to the eyes and the hands as they do to the ears.
Max
Posted on: 01 January 2016 by Jay Coleman
Thank you for sharing this, Max. Happy New Year to you and to your SBLs.
Posted on: 01 January 2016 by naim_nymph
Excellent write-up, Max.
I'm sure they're going to sound marvellous when plugged back in again.
I particularly like your phrase; "but I wanted to praise the thought behind them, the clever design, the smart use of the 'form follows function' principle"
SBLs do seem to be an invention of 99% very thoughtful design, and 1% style [choice of wood veneer]. But the SBL conception really does work superbly in practise, and the practical no-nonsense aesthetics only adds to the wonderful iconic charm : )
Posted on: 01 January 2016 by ken c
i have very  fond memories of the SBLs. but i guess the attention to detail in setting it (and other similar naim designs) is what let it down as, apparently, most dealers couldnt be bothered.
well done for taking time over yours -- the effort definitely pays off...
enjoy
ken
Posted on: 01 January 2016 by Stormange
I am also about to rebuild my 1998 cherry SBLs. Still waiting for the silicone that I ordered some three weekend ago. When it arrives and I have some time for myself it will be a pleasure to put on some new alupads and silicone. I have had the speakers for more than 7 years now and am pretty sure they will stay as long again.
Posted on: 01 January 2016 by Christopher_M
Thanks Max, very gratifying. So pleased you are now hearing your gorgeous speakers as Naim intended.
Best, Chris
Posted on: 02 January 2016 by hungryhalibut
Well done Massimo. I bet they sound great, and it's really satisfying to have sorted them out yourself. I've set up SBLs a few times, including changing the gaskets and pads, and filling the holes with plastic wood. All good fun.
Posted on: 02 January 2016 by DrMark
Fascinating account of getting your SBLs in top form - makes me wish I had done that to mine when I had them.  (I bought them new, but kept them for 10 years so I am sure they would have benefited from the service you so lovingly lavished upon them.)
And I agree with others; pics would be wonderful.  Buon anno nuovo Massimo!
Posted on: 02 January 2016 by Ian Stafford
I bet they're really singing now Massimo, well done and I totally get what your descibing about 'form follows function'.
I accidentally 'rocked' my middle box and broke the seal a couple of days ago and whilst I checked that the driver was slowly returning to normal after being carefully pushed in ( and I couldn't tell any audio deficiencies) I can't help but think I need to rebuild them. I'm sure it'll be a worthwhile job and I've done it before.
Question is, can you buy replacement aluminium pads/staples by themselves or is it just as easier to move them a few mm's and reuse them?
I'm sure the gaskets will be fine as the washing up liquid was carefully used on the last rebuild when the pads were found to be ok with no spikes going right through them.
Posted on: 03 January 2016 by Massimo Bertola
Ian,
I bought the pads are spare parts, they can be had from Naim but they have to be ordered by a dealer, or by an authorised lab. They cost 8 x £3.08, not cheap not exaggerate. After much deliberation, I decided to only glue them and not staple them, because I don't have a proper stapler and because I still wonder whether stapling them somehow doesn't contradict the principle by which they are used to decouple the woofer enclosure from the lower resonating chamber and the spikes must not pierce them through to the wood. But I have been advised by Steven Hopkins to staple them, so it's my choice and my responsibility.
All in all it's a pleasant job, not so difficult to be discouraging and not so easy to appear useless, and it brings your hands and time in close contact with the source of sound. I won't say it's a lutist's job, but it's definitely something beyond plug&play.
If one has more time, more patience and believes in going after perfection, there is this thread by graphoman:
https://forums.naimaudio.com/to...r-sbls-are-not-alike
to open up still another line of optimisation.
Best,
Max
DrMark posted:
As soon as I'm back home, in a couple of days..
Buon anno nuovo a te, Mark! Our home is open for you whenever you are coming.
Posted on: 04 January 2016 by Ian Stafford
Well stripped them down yesterday and gaskets were perfect (well done that famous washing up liquid!) and the spikes had only just broke through the pads and had made the faintest of holes in the wood. Manager to slide a thin blade under each staple and they popped out fine although the ones on the back 'struts' we're in pretty tightly so had a job with them. Cleaned everything well then placed the same pads back (after tapping flat with a 2oz light hammer) but rotating them by 180 degrees which meant that the spikes then rested in a new position on them. Re-sealed and put them back together, checked the space etc, placed Bowie's The Man Who Sold The World on the turntable and sat back.....sublime!
They may take a bit of TLC but boy do they repay that back!
Posted on: 04 January 2016 by Massimo Bertola
Ian,
glad to read that you've sorted it smartly without new pads, and if I understand it well, you even managed to re-use the same holes! We say la necessità aguzza l'ingegno.. Google it! In your case, I suppose necessity was more a wish not to spend £25 on tiny aluminium pads..
It seems that 2016 is beginning as a very favourable year for SBLs.
Best
Max
