Earth ground switch?
Posted by: Stu22 on 03 January 2016
Nac n272/XPS DR/NAP250DR ... In this set up should the switch be set to floating or chassis?
No problems but just want to ensure that everything is set up correctly.
Ta,
Stu.
Posted on: 03 January 2016 by sheffieldgraham
Depends on what source is connected to the 272.
If it's a Naim CD, which is grounded then set to float. If no other grounding is involved then chassis.
No harm either way. Which ever one sounds best to you.
I'm sure someone may be able to give a more comprehensive answer.
Posted on: 03 January 2016 by Richard Dane
That sounds about right Graham.
Posted on: 03 January 2016 by Stu22
No other source. Just the 3 boxes. Thanks guys.
