Active Speakers, Without Built-in Amps
Posted by: Allante93 on 07 January 2016
Naim Ovator 800/600
DBL’S
IBL’S
NBL’S
SBL’S
LINN ISOBARIKS PMS/DMS
When Active speakers are mentioned on the Forum, the above list immediately comes to mind, I’ve heard mention of the XD line from Dynaudio, Meridian's DSP range and the Exakt from Linn. Do they fit the above criteria, of not having built-in Amps?
I'd be interested to see what Naim/Focal could do with a system built around active speakers without built-in amps, in which case one could take advantage of Naim’s Amps!
What does ATC, and PMC bring to this Party?
Can they be added to the above list?
I did look up a $134K pair of PMC’s but they had built in Amps!
What is Naim's Strong suit?
Naim amps can swing transients in a way other similarly powered amps just cannot do.
What is Naim's Achilles heel?
Most would agree, lack of Power!
“Naim NAP500 At £18,000 this ought to be the creme of the power amplifiers but alas it lacks the magic of the NAP300 or NAP250 and despite it's enourmous extruded heatsinks it still gets hot with very little provoking. It is a bridged amplifier design largely due to Naim's fixation with using just two output devices. Despite being bridged it still only manages a very modest 140 WPC.”
Naim's cater to that is the ability to go Active( bi amp/tri amp).
Purpose of the Post is to see what Direction The Focal/Naim Merger might take us in.
“Focal has mostly loudspeaker experience but they also have powered speakers and automotive amplifiers. Naim is skilled at making compact, clean amplifiers and digital gear, so they can help further develop the amplifiers used in the Focal lines. Focal also produces powered subwoofers of course and all need amp modules, so having a top quality source is a good thing. They also push the envelope with regard to state of the art loudspeaker innovations and we might find an active x-over or powered woofer, etc in use in their home loudspeakers as well as pro monitors.”
It appears that both Naim and Focal can benefit from the Merger, Hence a win win scenario. It’s been stated that to do active properly a company has to be controlling both loudspeakers and amplifiers at a high performance level. There are very few manufacturers that are successful in both markets.
It will be interesting to watch developments as to whether the Focal/Naim Merger leads to more or less active systems?
Thanks In Advance for your Input!
The Armchair QB!![]()
