New to NAIM. Question for the experienced folks :)
Posted by: awn on 11 January 2016
First, I just wanted to say hi and thank you for accepting me to your forums. I recently picked up a NAC 152XS/NAP 150X, my first pieces of naim, and definitely not my last
The question I have is regarding balance. The system sounds great and balanced as far as I can tell at normal listening levels, but, I noticed as I slowly turn down the volume to 0, for really low listening levels, that the left speaker goes out first. At that point I can still hear music coming out of the right channel only. This would be with the volume pretty much as low as you can get it while still being able to listen. As I slowly turn the volume back up, the left speaker comes back on at a bit lower level than the right until the volume gets back up. Is this another one of naim's quirks? Or should I be concerned? Hopefully someone else in here has noticed this or can try it out to see if their system does the same. Thanks in advance!
