Nait2 mains cable
Posted by: Jazzy on 12 January 2016
Hi
The other day I discovered that the mains cable of my Nait2 is brocken, the insulation is ripped and I dont feel safe using the amp. The damage is on the back side where the cable enters the box.
I would like to have the cable replaced, and I'm aware that the replacement is something that should be carried out by a pro.
My concern is that replacing the cable with a random cord will damage the sound of my fine little amp, so does anyone know which cable was originally used. The cable has no name no info written on it.
I have a box full of "spares", and I have found an I-Sheng 0,75 and a Tongyan 0,75, both from the 90's, would any of theese be suitable?
I will be very thankfull for any information concerning the matter.
Posted on: 12 January 2016 by Richard Dane
Your best bet is to make contact with Naim's service dept. who will not only replace the cable for you (properly and safely) but also will be able to fit the correct cable.
Posted on: 12 January 2016 by Jazzy
Will do
Thanks Richard
Posted on: 12 January 2016 by cristianr
You could just take a screwdriver, open the box (4 screws), cut the cable just after the insulation is ripped, remove the part that remained mostly inside and connect the rest of the cable instead. You'll have a slightly shorter mains cable. Easy  and safe, just use common sense.
Posted on: 12 January 2016 by hungryhalibut
Assuming that Lynge is in Denmark, I certainly wouldn't be sending it back to Naim in the UK. I'd take it to a local electrical repair shop - just get the cable shortened as suggested above. So long as it can be soldered correctly, it will be fine.
Posted on: 12 January 2016 by ChrisSU
I believe Naim have an agent in Denmark - and a few dealers. Surely one of these could manage it themselves without sending the unit all the way to Salisbury?
Posted on: 13 January 2016 by Richard Dane
Jazzy, if you're outside the UK then best have a chat with your local Naim distributor.
Posted on: 13 January 2016 by Mike-B
Its a simple job for a TV/Radio/electronics service technician.
Its an ordinary cable & soldered to the internal connections
Posted on: 13 January 2016 by Jazzy
Thanks all for your kind replies.
Take my apologies but I might not have made myself completely clear in the first post.
Besides the fact that the cable is broken, it is also quite short, the first owner must have cut it, for what ever reason. Maybe it has been fixed before. The short length gives some inconvenience concerning flexibility when placing the system.
I am perfectly aware that replacing/ cutting the cable is a piece of cake for a technician.
My question was rather who was the original producer of the main cables used back then, 1990, and is it stil available, or do you have other recommendations?
Kind regards
The cable itself was probably Pirelli as that was the mains cable that was being supplied with the rest of the kit back around that time. AFAIK it's long out of production . For all that, Naim may be able to tell you for sure.
