Forum Date Format
Posted by: Dungassin on 12 January 2016
Just noticed that the Forum Date format is in the 'American' order.  i.e. Month/Day/Year.    Don't know if it's always been like that.
Any way of changing it to the British one of Day/Month/Year?
Posted on: 12 January 2016 by Simon-in-Suffolk
Strange, I noticed this today as well, and I have found no way of changing it... perhaps another bug?
Posted on: 12 January 2016 by BigH47
Why can't the colonials do things right?
Posted on: 12 January 2016 by winkyincanada
Dungassin posted:
It is not in the "American" order, it is simply in the wrong order.
Posted on: 12 January 2016 by Erich
It was mentioned by Brian M in New Forum Bugs 12/3/15.
Using a different convention is not necessarily wrong, I also prefer  dd/mm/yy or  yy/mm/dd.
Posted on: 12 January 2016 by Jan-Erik Nordoen
The date format is set by your browser and can be adjusted as desired therein.
In case of using MAC+Safari adjustment should be done in Sys Pref.
Posted on: 13 January 2016 by Pev
I reported this right after the Forum update and was told to alter the browser settings but that made no difference whatsoever in both Chrome and Firefox. All other sites I use have the correct format. I find it intensely annoying!
Posted on: 13 January 2016 by rjstaines
Well it would have been fine on the eleventh of November five years ago.
(if you don't find this to be a helpful post, please just ignore it)
Roger
Posted on: 13 January 2016 by Dungassin
Winky : I said 'American' because that is the way they seem to do dates.   I don't believe it to be 'wrong', just not the way we do it in the UK.
Erich : I checked this.  just now.  Mac Mail had short format dates in order Day/Month Year.   SoI checked System Preferences on my Mac (System Preferences>Language and Region).  Date format for Medium and long is Day/Month/Year, but for Short was Month/Day/Year.  I have dragged the month field to the left.   Then quit and restarted Safari.  Dates on Naim Forums still in wrong order.
Posted on: 13 January 2016 by Richard Dane
As I posted in the bug thread, according to Hoop La you need to set this in OS and browser preferences.  Unfortunately it seems that you need to have both of these fully up to date and latest release and also Safari may have a bug here.  So, yes annoying, but according to Hoop La it's working just fine (for them)...
Posted on: 13 January 2016 by Don Atkinson
Richard Dane posted:
................ according to Hoop La it's working just fine (for them)...
Says it all really.................!!!!!!!!!!!!
Richard,
I have checked on the other 2 forums I occasionally frequent :
AVForums shows dates in either medium or long format as e.g. January 11th 2016 (i.e. not the format I wish it to in).  However, I can live with that as they are not using the short date format.
Asset/dBpoweramp Forums show dates in short form as Day/Month/Year.  Thus the above date would be 11/01/16
Naim Forums show dates as 11/01/16
All these examples are AFTER I checked the date format in System Preferences.  There is no facility within Safari itself to change the date format as far as I can see.
My OSX El Capitan and Safari are fully up to date according to the App Store (i.e. no updates offered by App Store)
Posted on: 13 January 2016 by hungryhalibut
I don't see this problem - here is a page I've just looked at to check...
Posted on: 13 January 2016 by Alfa4life
After a bit of fiddling with El Capitan / Safari I have got date correct.
System Preferences>Language & Region
Mine had English in panel, adding English (U.K.) and putting it at top of list fixed date format after a restart.
Posted on: 13 January 2016 by Mike-B
My date format is OK (for me)  with dd/mm/yy
Posted on: 13 January 2016 by joerand
My format (mm/dd/yy) looks fine to me. Even if it was dd/mm/yy, I'd easily adapt and move past it.
Now if I can get the forum time set to the 'correct' Pacific Standard Time ....
Posted on: 14 January 2016 by Erich
Dungassin posted:
Is your  setting for language to "English" or "English UK".
I use MAC and if I set language to English then date is shown mm/dd/yy but when set to  "English UK" then I see dates dd/mm/yy.
Regards. Erich
Posted on: 15 January 2016 by Dungassin
That turns out to be the problem.  I hadn't actually noticed English UK was second in the list.  Why, oh why, doesn't it default to English UK if region is set to UK?  Surely that should be the default setting for region UK?   Anyway, problem solved.
