iFi "iPower" SMPS - carried over from HiFi Corner
Posted by: Mike-B on 13 January 2016
Thanks Mike, very informative.
As I am a mechanical engineer rather than an electrical one , I am not sure what the comparative (iPower vs Netgear PS) figures mean. Do these mean the iPower is performing in a more stable manner or are these differences insignificant?
As you indicate however, it is the difference in SQ that really matters and clearly these differences are subtle and you need more time to evaluate them. I look forward to hearing your considered view on the iPower.
N
I'm surprised you've not gone down the Ethernet > Fibre > Ethernet route for ultimate isolation of the NDX from the network Mike. Your PS powering the Ethernet to Fibre converter at the NDX end could then be your best quality one. Maybe something worth trying (Dave BK did this and so has Andrew Everard) if you're in the mood to explore further ?
James
nigelb posted:As I am a mechanical engineer rather than an electrical one , I am not sure what the comparative (iPower vs Netgear PS) figures mean. Do these mean the iPower is performing in a more stable manner or are these differences insignificant?
Hi N, I see the stability in the Netgear unit as indicative of the possibility of lower quality especially in the VR section & the voltage drop under load as possibly working near its limits.
Yes SQ is the all important end, problem is I trust my voltmeter more than my ears ![]()
james n posted:I'm surprised you've not gone down the Ethernet > Fibre > Ethernet route for ultimate isolation of the NDX from the network Mike. Your PS powering the Ethernet to Fibre converter at the NDX end could then be your best quality one. Maybe something worth trying (Dave BK did this and so has Andrew Everard) if you're in the mood to explore further ?
James, I am not really that interested in the ethernet fibre route, & I understand its not quite that simple. I intend to take a look sometime, but maybe not until I get other stuff like a possible house move sorted first.
Mike fibre is fairly straightforward - but as the NDX uses electrical interfaces - you still have to have an 100/1000BaseTX switch or transceiver to contend with - and course these can create noise..
I will be following this thread,but a quick question.
Are we talking switch only smps for improvements or also nas and router?.
scott
Good question.
Simon-in-Suffolk posted:Mike fibre is fairly straightforward - but as the NDX uses electrical interfaces - you still have to have an 100/1000BaseTX switch or transceiver to contend with - and course these can create noise..
Just for those who are interested in such experiments, if you buy the right fibre converter then you can plug directly into the NDX but will need a fibre converter supporting 100Mbps as the NDX (like all Naim network devices) are not 1000Mbps (gigabit) compatible.
But the converter, or at least all the ones I am aware of and use, will need powering
Understood Mike - just thought it would give you the biggest bang for buck (and i think when i looked at it, the cost (and effort involved) was fairly minimal. Out of interest is your switch close to your gear or off somewhere in another part of the house ?
Scooot posted:I will be following this thread,but a quick question.
scott
For me its a toe dip & look-see into the switch SMPS, at this time I have no suspicion that NAS (especially) or router is adding noise. If & when I find it/they are, then I will go look again. Regarding NAS, a Lin owning friend with the same NAS make as mine, bought a LPS that cost almost as much as the NAS, he is particularly disappointed as he hears no change, so will need some persuading.
james n posted:........ Out of interest is your switch close to your gear or off somewhere in another part of the house ?
Mike-B posted:Simon-in-Suffolk posted:Mike fibre is fairly straightforward - but as the NDX uses electrical interfaces - you still have to have an 100/1000BaseTX switch or transceiver to contend with - and course these can create noise..
........ thats what I meant by " & I understand its not quite that simple".At some point we all get arrive at the far enough zone, I'm close to that now.If I can convince myself that I have minimal noise on my ethernet LAN, that's it.
Mike, the way to measure noise and confirm you have minimal noise on your LAN Ethernet leads is to place an EM / RF meter by them... I suspect you might be shooting in the dark a little bit with out it..
Regarding fibre, I mis understood you, I though you might have been referring to the different fibre types and adapters (OM1,2,3,4) and their optimum frequencies and distances.. That can catch you out.. Or at least it has me me in my professional capacity.
Hi MIKE-B
cheers for the reply.
Mike-B posted:......................................... Measuring the iPower in comparison to the Netgear SMPS showed the Netgear voltage varied & the iPower was very stable to >0.01VDC.OK that's the numbers, what about the SQ.First impression is something has changed, not at all sure what, its subtle & not easy to define other than its different.
Second impression is yes something has changed, its subtle in some areas, others like clarity & naturalness is more obvious.
Mike - thanks for the feedback. It seems that some of the improvements brought about by the iPower are not so subtle! Quite an achievement for such a modest bit of kit. Very clever if(i) they have managed to remove (cancel) a lot of noise with such a simple but smart design.
For a mere £40 it has got to be worth a punt.
Many thanks for your detailed testing and feedback - much appreciated.
I'll let you know how I get on when I get mine installed.
Sorry to hear about your ethernet plug connector woes - hope you got them sorted without too much angst.
N
Hi Nigel, please don't misunderstand me, I said in my post this morning that its subtle & not easy to define other than its different. At best these changes are small & the degree of the changes could be a matter of how good or bad your set up was before installing the new power supply, what it does for me might not be the same as for you.
Understood Mike and I also realise you have already done much to suppress noise in your LAN. I too have done quite a bit to optimise my LAN.
Even though subtle, it does however appear that there are improvements possible with the iPower and at £40 there is little risk. I'll give it a go and see. If I hear no difference then I haven't lost much.
N
Mike-B posted:The only downside is I've had a broken ethernet RJ45 plug connector clip & for some reason I lost all my NAS settings so could not get on with listening while I f-f-fiddled around sorting that mess.Anyone got suggestions for ethernet port plug clips that don't break.
Update - The broken RJ45 plug clip is contagious, another f-f-f-clip has broken. This is very annoying !!! Looking at the clips its pretty obvious they are not ideal for much other than a one click connection & will not take much in the way of in-outs & cable movement.
Anyhow, I've bitten another bullet & ordered two new MeiCord cables between NDX -switch - NAS. I am not a believer in ethernet cables other than engineering quality is far far more important the the price of snake oil & buffalo droppings. These cables claim to have a real quality plug & it looks like it. It also looks like the price of the cable is all about the plug & install labour rather than the cable itself; the price diff between 0.5m & 3m is £12.
So, here (or should that be "hear" ) - we go again, more later
Hi MikeB,
Before Christmas I, too, did the Ethernet switch power supply upgrade and my conclusions were the same as yours, a small but positive upgrade to SQ, more organic and open sound. I would recommend others to try this simple cheap upgrade for streaming.
Mike-B posted:Mike-B posted:The only downside is I've had a broken ethernet RJ45 plug connector clip & for some reason I lost all my NAS settings so could not get on with listening while I f-f-fiddled around sorting that mess.Anyone got suggestions for ethernet port plug clips that don't break.Update - The broken RJ45 plug clip is contagious, another f-f-f-clip has broken. This is very annoying !!! Looking at the clips its pretty obvious they are not ideal for much other than a one click connection & will not take much in the way of in-outs & cable movement.
Mike, I realise it is a bit late and you have ordered the MeiCord ethernet cables but you were asking about ethernet port plug clips that don't break. From your profile I am guessing that you have had this problem with the Supra ethernet cables. I use Audioquest ethernet cables throughout and have never had a problem with port clips breaking. Now I know you won't subscribe to snake oil but I have had great results from the better ethernet cables in the AudioQuest range. I use Vodka between NDS, switch and server (Unitiserve) and Cinnamon everywhere else. In fact I got sent the longer length of Vodka because the supplier was out of the Cinnamon I ordered. Not sure I would have gone to this expense if I had to pay the cost for Vodka. I notice you also use AQ Pearl ethernet cables. I wondered if you might be able to borrow some 'better' ethernet cables from your dealer to see if it is snake oil or if you detect a worthwhile improvement.
Have ordered a iFi iPower today and will let you know how I get on.
OK Mike, its a no for the ethernet cables. I do however have some rather wonderful oil that pretty much cures every ailment at £99.99 a bottle. Interested?
Please forgive my thickness, but I find it a bit hard to unpick the conclusions from the above discussion. I've read in a number of places that SMPS 'wall warts' can inject noise back into the mains. I don't particularly understand what that means, other than that it seems likely to have a detrimental effect on SQ of other boxes. As a result, though I can't eliminate them, I try to keep SMPSs plugged into different sockets than my black boxes. If not at the other end of the room, then at least not on the same power strip.
Is that about right, at least as a description of the problem?
If so, is the upshot of this experiment that this iPower device reduces/eliminates that problem? I.e. does it mean that e.g. one of them could be used to power a network switch from the same 4-way as the amplifiers without SQ detriment? Or does the iPower do something else (obviate the need for shielded signal cables to some extent, for example), and other solutions are required for the noise injection problem - silencer devices, perhaps?
