Setting up phono on Nait3R
Posted by: Naimestea on 15 January 2016
New to forum and have some dated naim gear that I'd like to expand and was hoping someone had experience with the following:
1. Setting NAIT3 up for phono w/ a stageline.  Would current stageline models be compatible or do I need to find a similar vintage unit?
2. Would a separate power supply be needed or could the NAIT power the stageline?  If a separate PS is needed - any recommendations would be great.
The speakers are Credos - same vintage as NAIT so system may benefit from an external PS it seems (if I understand the pecking order correctly)
Thanks in advance for your input.
Posted on: 15 January 2016 by Naimestea
don't own stageline - but thought it would be a more flexible and superior solution.  What am I missing?
Thx - will check into this solution.
