N272 Volume Control knob
Posted by: fernar on 18 January 2016
Very please with my N272 (still less than 100 hours old).
While trying all the functions - I noticed that the volume control know was a stiffer to turn vs the home demo unit that my dealer lent me.
In fact I went into his dealership to make sure that what I recalled was in fact true - what I discovered is that the stiffness of the knobs seems to different by device - so his N272 had a very loose easy to turn volume knob - his N252? pre-amp's volume know was stiffer, and the balance control even stiffer - about the same as my N272...
The the stiffness get less with use? Or the control stiffness level I have now what I will have to expect from now on? I was surprised at the level of variation - but is this to do with the fact that NAIM are hand built?
The control stiffness is not a major issue - but it would have been a bit nicer to have the same 'free -flow' as my dealers demo unit...
Posted on: 18 January 2016 by David Hendon
My NAC N272 volume control knob is much stiffer than the knob on my SuperUniti and I was also surprised when I discovered that.  It's only a month, but the N272 hasn't got noticeably less stiff.  Mind you it doesn't get a lot of use because I tend to use the app.
best
Posted on: 18 January 2016 by hungryhalibut
One has to be careful to avoid double entendres on these 'knob' threads, so choosing my words carefully I will say that the knob action on my 272 is exactly the same as that on my previous SuperUniti. Both turn easily, and both are/were silky and smooth. If your knob is too stiff and you find using it uncomfortable, perhaps you should ask your dealer to send it back to Naim for a little lubrication or a replacement. On the other hand, if it's not that irritating, just live with it. The fate of your knob is in your hands.
It's all a matter of whatever turns you on.......
Posted on: 19 January 2016 by Huge
David Hendon posted:
Isn't that the switch at the back?
Posted on: 19 January 2016 by GraemeH
Hungryhalibut posted:
That then is what my teenage kids would call... an 'epic fail'! Dick Emery would indeed be proud!
Posted on: 19 January 2016 by David Hendon
Huge posted:
Not with Naim, because you leave the power on all the time and just turn up the volume to "turn it on"!  (That's the best I can come up with, to what was a very fair challenge.)
And as Graeme implies, I also think we should all hold HH in awe for his wonderful input to this discussion yesterday. I hope the OP has found this all to be useful!
best
Posted on: 20 January 2016 by SongStream
 Awesome.
