Does SuperUniti need WiFi enabled for Spotify Connect to work?
Posted by: ChrisByrd on 20 January 2016
I thought I'd give Spotify Premium a try but am unable to connect to my SuperUniti. The SU doesn't show up on the list of Devices Available in the Spotify app, either on my iPad or iPhone. Streaming from Tidal and UPnP via the Naim app is working fine.
I've searched this forum but can't see any obvious answer. The Amazon FireTV Stick does show as a Spotify Connect device, so is it possible that WiFi needs to be enabled on the SU for it to work with Spotify, or am I missing something obvious?
Or would I be better sticking with Tidal Premium for the same cost as Spotify?
Thanks in advance
Chris
