Ripping Yarns 2
Posted by: Mr Underhill on 28 May 2011
Hi,
Last time I left you at this point:
..... I have thousands of LPs. Many are not available on CD.....
..... [My recorder has] three selectable input levels, [and all of them are] over-load [ed by my pre-amp]
..... Not using my pre amp means that I have to apply RIAA after the fact,....
..... Overall I think this is a painful process.
..... and then probably only carry this out with vinyl that I can't get on CD to be honest - life is just too short!
..... But when I can record using Tom De P. phono section I might be open to persuasion!
So, in brief - I solved the pre-amp issue, and I have been recording more LPs digitally; so thought I'd write a brief update, and answer the following questions:
1. Are the recordings via the pre-amp section better than applying RIAA after the fact?
Not always
2. Are LP rips better than CD rips?
Not always
3. Will I continue to rip LPs?
Err, not always!
Where I have got a good rip direct, w/o the pre-amp, the pre-amp hasn't improved matters - this has happened once.
On the whole it is far easier to get a well saturated recording using the phono section of my pre-amp.
Generally they are the best rips I have, BUT - it comes down to the quality of the source material.
Two examples:
High Society
Mono recording that I ripped. Vinyl full of pops and clicks.
Somehow, when played back through the turntable these defects are FAR less intrusive. Via a digital file they are a complete distraction.
So I bought the CD.
The quality of the recording on the CD was truly appalling. The bass was better, but the backing musicians sounded as though they has been recorded in a lavatory.
I went back to the LP, and invested a lot of time cleaning the tracks - worked, and now sounds good.
--Principal 1: If you have an historic record it is probably worth investing your time capturing the tracks and repairing them.
The Kick Inside:
Clean vinyl. Not a first generation pressing.
Ought to have been a good transfer.
Bad pressing. Poor quality rip - a CD track of 'The Man With a Child in his Eyes' was far better.
--Principal 2: Source quality counts - not the medium.
Bearing in mind the Principles above - absolutely.
I just ripped Stokowski's Beethoven Decca 4 pressing of 5th and 9th symphonies ....and deleted them,
Via the turntable they are fine. Digitally the pops and clicks abound.
I have a number of versions digitally already, and so will not invest time cleaning the files.
The best LP rips I have to date include:
Guacho
Sheffield Steel
The Dreaming
Moving Pictures
Out of the Blue
Made in Japan
The Living Years
True
Let It Be, Naked
Born in the USA .......
Great rips - beating the 9624 files I have bought commercially. Why? For me the quality of the vocals echoes what I get from the turntable.
Turntable -vs- Digital
Generally I would say playing the LP helps me just concentrate on the music, it is far kinder with defective LPs, not highlighting the problems.
Digital replay resolves far more detail, including any issues on the source LP. Where the source is clean the effect can be spectacularly good.
Looking at the captured files there is content well above 20k KHz, although very diminished.
Spending time working out how best to clean my historic pressings - working on Oscar Peterson first!
M
