Upnp Nas device for uniti
Posted by: RM on 05 June 2011
Can anyone recommend a upnp capable Nas device which I can use for streaming with uniti? Budget max 500 but would prefer a good option around 150 to 200 that is compact and offers a good overall solution.
Sorry I don't know how to use the search function on forum so apologies if this has been discussed previously.
Thanks in advance
Rohit
Vortexbox IMHO - though it is more a music server par excellence than a NAS though it'll do everything a NAS will do and make the tea. You can buy a ready made one to suit your budget or make one yourself (the software is free).
All the best, Guy
PS - Here is the search engine in action - please click here.
Is the UPnP server on the Vortexbox basically Twonky or is it something different?
Are you using it to stream to a Naim device, what's your experience?
Simon
The standard installation is set up for fac with either mp3 or alac (mirrors) - since ripit creates a wav file when it rips I believe the Vortexbox can be configured (at the command line) to keep the wav files for streaming. I think Sonore make music servers that come ready configured this way.
Tog
Simon
Hello Simon & Tog,
I don’t know how relevant this may be, but I run a ReadyNAS_nvx that as Tog says is basically a miniDLNA server, similar to Vortexbox.
I have never been able to get the NAS server to present WAV files to the Qute for streaming; flac are fine. I don’t use wireless so no experience with the Apps, however, Kinsky DT and Asset CP never show the WAV files for selection.
The only time that WAV files have been playable is when I put Asset UPnP on a PC to try. Asset control point (run on a netbook) was then able to see and play the files. This was not an acceptable long-term solution to me though, not wanting to run Asset on another PC.
I have not found either Kinsky or Asset control points work reliably when looking directly at the NAS server, they simply stop working after a few tracks or an album if lucky.
I am very suspicious of the UPnP server on the NAS, it doesn’t seem to play well with other software, however, it has been virtually faultless when used via the Qute’s remote control now that I have resolved an issue of over large artwork on some files.
Peter
I think MiniDLNA is indeed derived from ReadyDLNA - written in house for their NAS but MiniDLNA now has a life of it's own. Running on Fedora (Vortexbox) so far I have found it pretty faultless and very quick with flac. The issue of wav is more complex since MiniDLNA does not stream wav "out of the box" and Sonore servers can use wav via dig out or mpd. There is some discussion on the VB forums that I sparked off a few weeks ago as to the potential to transcode to wav and the available settings within MiniDLNA.
A MiniDLNA update has just been issued to Vortexbox.
Tog
Is it a bird, is it plane, no it's a VortexBox.
Hi Tog
Thanks for that, I have asked the question about WAV streaming on the ReadyNAS forum but it has gone unanswered, so your information is appreciated.
For me the problem is not having found a control point that will work with it, both Kinsky and Asset C P’s stop working usually after just 1 – 4 tracks have played.
However, yesterday after months of searching I stumbled across a C P named 4u2stream, and this has played the NAS files absolutely faultlessly for the past 2 days, 180 tracks yesterday without a single hiccup no matter how I tried to trip it up. The only drawback is that it is text based; artwork is only seen for the playing track so not as easy for others to use.
Hi Guy
Well, that certainly looks the part. I would very happily purchase a separate music server, in fact I would prefer this option; I just need to be sure I can control it with a CP on a netbook. The Userve is the obvious choice I know, but as it’s digital out is said to be no better than the Qute’s, I don’t like the PS or the slot loading CD, I have to look elsewhere.
Peter
Hi Guy - the VB appliances are good value but if you search around you can source much better looking and quieter servers for installing your own copy.
Tog
I'm currently running the Acer aspire easystore H340. This is a Windows Home Server NAS which I am running the Asset UPnP on. Works well for me and I think these can be picked up for about £350.
Stuart
Simon
Simon,
Interesting, which model of the ASUS did you buy. By the way I am now ripping to uncompressed FLAC rather than WAV (although not streaming). I would not expect there to be any SQ difference compared with WAV and indeed I can't hear any. Might help in narrowing NAS choice if you are happy to rip FLAC.
Tog
Hello Tog
Unfortunately wireless is NOT an option for me. Not a problem as the property is fully wired and has a 24 port Gigabit smartswitch as its backbone. Although, I would not deny the attractiveness of a small remote if it were possible, but a netbook will work well for us, as a large proportion of our music is classical with its usual long lines of text.
Peter
Simon
Hello Simon
Oh, that’s strange; I have never had problems with flac files on the ReadyNAS; that is if I disregard problems I had with some files not playing. This was sorted last week when Av from Naim asked us to check the artwork file size of these files, turned out they were up to 10Mb which is quite crazy really, a quick resizing seems to have completely sorted the problem.
I like the idea of the solution you and Stuart, on the post above yours have put in place. It seemed to work well when I briefly tried it on a PC. I really like the idea of a separate dedicated box just for music.
Peter
Hello Cpdm,
Its good to know. Is the Duo able to stream WAV files? I doubt that it can but it has a different OS to mine so would be interesting to know. Are you using a CP to control your streaming?
Peter
It has Twonky pre-installed on it. Some do not like it, but it does the job for me OK.
There are a lot of features on the NAS that I'm not in need of, but it seems to be very robust.
Had a few problems setting it up originally as I could not get the IP addresses set to work, but I think that was more an issue of my lack of knowledge and router iSsues rather than anything to do with the NAS.
> Some do not like it
Always the way I'm afraid - nothing seems to be universally loved by all.
I know a dude with the QNAP as he's really happy with it.
You and Gary seem to like yours
So ... it seems a good option
Possibly the next best thing to the Vortex.
All the best, Guy
