Unitiqute Issues
Posted by: Benji on 05 June 2011
I've lived with my Unitiqute for a couple of months now. Some things it does brilliantly, but it does seem to have a fundamental flaw. And that is in the UPnP functionality.
I'm running a Macbook Pro with EyeConnect, accessing my iTunes folder. The Uniti is connected to my Wifi Network, with an Apple Time Capsule router providing the wifi signal.
Basically, all will work well for a while, albeit a little slowly. Listing of tracks seems to take a long time to load up (why no cacheing?) especially using the n-Stream app. But once loaded, the files play beautifully.
If I then stop playback, and leave the UQ overnight, for example, coming back to the box in the morning and trying to connect again invokes the "Please Wait Input Initialising" status on screen, and there it stays. The only solution is a hard reboot, which solves the immediate issue, but it's not really a long-term solution.
Even when the input will work, I often get a <No Server> error on the UQ display, even though I know full well that EyeConnect is running. Solution here is to reboot the Mac, but seriously, how much rebooting should be expected from a wireless system?
I've gotten so frustrated with this that last weekend, I thought okay, let's just load all the 50GB of files onto an external drive and use the front USB socket for fast and immediate access, all the time. Alas, that doesn't seem to be much of a solution either - again, the UQ can access the USB drive and play back files, but again, upon leaving the unit powered up, a return after a few hours brings up the "Please Wait, Input Initialising" error.
There seems to be a basic lack of stability here. I am sure that perhaps switching to a fully wired solution between Mac and UQ might help, but I am loathe to run Cat 5 across the floor, or go out and purchase Powerline routers, as the UQ is billed to be completely happy with a WiFi connection.
I'd love to hear from Naim or other users about how I might be able to resolve the issues here. All I want to do is to be able to get the UQ to connect to my UPnP library, and playback files with no issues, be able to leave the UQ powered up and come back in the morning and have it work flawlessly! Right now, I'm even considering getting a UnitiServe just to avoid the issues listed, but that would still mean I have to get MP3 files from the Mac to the Unitiserve - and it still means that the UQ doesn't perform it's function as it's listed on the tin!
So come on Naim, surely you can do better than this. I've dropped over £1400 on this, including Naim speaker cable as recommended by the dealer. I previously had a Logitech Squeezebox, which cost a tenth of the Unitiqute, but also gave me a tenth of the issues! I expect better, honestly.
