I see no-one has replied, which may be because it isn't clear what you are asking. You can certainly use your muso on wifi if you want to, although generally people agree that hard wiring with Ethernet can give overall better sound quality and you are less likely to run into problems with the wifi causing drop-outs etc. But if you wifi signal is strong and you don't have lots of other people using your wifi or interfering with it in properties close by, it will be fine. Regardless whether you use wifi or not for your muso, you can use the naim app on IOS or Android, over wifi, to control the muso and there is no advantage to trying to do it any other way.
I hope this helps but if it isn't answering your question, please elaborate and one of the members here will no doubt be able to.
best
