Relics from the original Naim logo?
Posted by: joerand on 24 January 2016
Can anyone identify these objects?
Posted on: 24 January 2016 by sjbabbey
Black puddings ?
Posted on: 24 January 2016 by TOBYJUG
Turntable warmers.
Posted on: 25 January 2016 by joerand
Not turntable sized, only 19-mm (3/4-inch) in diameter. Well hidden, disposable, yet common household objects, I had three pairs of them that I only noticed when doing some maintenance on my 22-year-old dwelling.
Posted on: 25 January 2016 by Graham Clarke
Toilet seat warmers?
Posted on: 25 January 2016 by sjbabbey
Toilet seat washers?
Posted on: 25 January 2016 by TOBYJUG
Grommet Warmers ?
Posted on: 26 January 2016 by joerand
They're not warmers of any kind, but Graham and sjbabbey have nailed the household appliance from which these originated!
Posted on: 26 January 2016 by hungryhalibut
Aren't they the little washers that fit between the metal seat fittings and the China pan?
Posted on: 27 January 2016 by joerand
Rather than outside, think inside the box.
Posted on: 31 January 2016 by joerand
Used in the toilet tank, they are the nylon chain keepers that position the adjustable float between toilet handle and flapper valve. One above and one below the float.
Shown here in white:
Posted on: 02 February 2016 by blythe
Not in a standard UK toilet !!
Posted on: 03 February 2016 by joerand
Indeed. Chamber pots have no floats, chains or flapper valves
Posted on: 04 February 2016 by Dungassin
That reminds me of visits to my great-aunt in Clitheroe back in the '50s.  They had an outside toilet of a type I think is called a tipper toilet.  Basically a hole cut in a board over a bowl which would empty itself when full!  These youngsters know nothing ..,
