NAS
Posted by: dottore17 on 24 January 2016
I have been trying to install without success a Netgear NAS with WD hard drives.to back up a UnitiServe. The first one was found to be faulty when I returned it to the suppliers, the second one  did not connect via one of the slots as determined by Netgear themselves during an extensive telephone support session. Has anyone else had a problem with this product?
Posted on: 24 January 2016 by Graham Russell
Which product? Model number? It's important to make sure the NAS supports the size (capacity) of drives being installed. I've discovered that not all NASes support all drive capacities. This is probably not your problem, just an observation.
Posted on: 25 January 2016 by dottore17
Thanks. The drives were checked by Netgear and found to be compatible.
Posted on: 25 January 2016 by David Hendon
Netgear has a good reputation so I think you have been unlucky. I use their unmanaged switches as a matter of choice, but I haven't tried their NAS (I use Synology).
Once you have got a NAS that works, if you can't configure it to back up your US then you should talk to Phil at Naim support because he will be able to help you.
best
Posted on: 26 January 2016 by dottore17
Thanks. Phil it was who recommended Netgear. I am persisting with the product, having asked the suppliers install the hard disks themselves and test it, only sending it to me when they could guarantee that it was working.
Posted on: 27 January 2016 by David Hendon
Sounds like a plan!
But what I meant was that Phil can help you configure your Nethear NAS if you want, for example by remoting into your PC and making the necessary settings in the US and the NAS.
Best
Posted on: 27 January 2016 by dottore17
That's right. But in doing so Phil recommended using Netgear equipment. I reckon I've just been unlucky. I look forward to receiving replacements that work.
Posted on: 27 January 2016 by Mr Happy
Phil configured my friends unitiserve with a synology 213j nas. He somehow logged into my friends system and sorted it perfectly. What a great service! Of course you will need a working nas first
Thanks. I've used Phil before when I had a minor problem with the UnitiServe. He's great.
Yes he did this to for me with my Synology NAS.  I am sure the Netgear NAS will be fine once the OP gets one that works, but configuring a Unitiserve can be a bit of a trial, which is where Phil can easily help.
best
Posted on: 27 January 2016 by Checkthisout68
+1 for the Synology NAS together with HDX
