What power bar are you using ?
Posted by: Jan-Erik Nordoen on 26 January 2016
In keeping with this month's theme...
Bis Audio Power Bis
Cryo-treated, naturally.A/V Options version, also cyro-treated.
Audience Adept Response
Two custom hydras, each ten way
Wireworld Matrix with powerline.
For Maximum Energy Delivery
None.
I plug everything into Oyaide R1 wall outlets.
When I need extra sockets, then I use Oyaide MTB-4 R1 strip.
Audience AR6 PDC, on its own tiny home made glass and fibreboard "ball nutter" shelf, with an AV Options cryo-treated PowerCon cable. Trusty old Wireworld daisy-chained off that for the "lesser" boxes.
Musicline Powerigel 6
pz posted:Wireworld Matrix with powerline.
+1
QB8. ![]()
Chag -
NANA "Noise Trapper" Cable Pro outlet strip, on a cherry wood board with dome nuts.
The sturdiest thing I could find for under GBP20 with 6 sockets that came with a 5m lead. And then a bunch of PowerLines into it.
I've got the NANA Noisetrapper as well. Mine's sitting directly on the carpet but made a recognizable improvement versus plugging into several wall sockets. Old school and bulletproof.
My system only has two plugs, which both go directly into a double unswitched wall socket, on a dedicated 10mm mains radial.
Enerr Holograph (made in Poland)
Cable pro NANA approved version.
Home made using 6 MK unswitchrd sockets mounted in a board cut to take them, wiring is chained rather than star though and its lead is captive, the backing board is channelled to take the wires and is of a different wood. Plug order is the reverse of some here with 555ps nearest the cable then 552ps and 250 with the Merlin on the last socket, I tried the reverse when i had a 282 but coherence suffered. The tuner goes direct into the wall as it upsets everything else if I plug it into the block, Bu**ered if I know why.
I've been considering the Heratic Audio copper star block which looks similar to mine but is star wired and has an IEC socket (at which end is optional) but it's a bit thick and I've not much space behind the Fraim to get the powerlines under the rack without touching it so have hesitated for some time.
Wireworld Matrix 2 with a Powerline to plug it in. No cryo treatment I'm afraid, slumming it with a room temperature jobby. Better than the Grahams hydra that preceded it though.
Wireworld Matrix... No Powerline to it as Naim don't make one 4metres long.
Mark Grant mains block
AV Options cryo Wiremold
Like it
Tripp Lite Isobar 8. Best you can get for the price.
Atlas EOS Modular power distribution block, works very well. Power line into block from mains, regular NAIM IEC leads into amp/streamer
http://www.atlascables.com/eos...er-distribution.html
None - all directly into 4x double switched sockets on their own loop - had this done when the house was re-wired about 15 years ago...
