SBL Crossovers
Posted by: progan on 30 January 2016
Hi
Trying to find out how old my crossovers are. They don't have a little white sticker on them , just one blue and a yellow circular sticker with 708 709 on them respectively . They are 1988 SBLs. Any ideas?
Posted on: 30 January 2016 by naim_nymph
progan posted:
Hi
What are the serial numbers on the SBLs? [usually the same number]. You can look up the year of manufacture from the serial number.
If you don't know the history of your SBLs there's no knowing for sure how old the x-overs are, they may of been used actively by a previous owner, and then passively with x-overs attached at a later date. But i would think most SBLs were used passive so would have had x-overs from new.
Posted on: 30 January 2016 by progan
Hi they are 41177 so 1988 speakers, I got them from the original owner so always been passive, Had mk2 2 bass drivers and new tweeters fitted at some point as well
