Living room re-jig
Posted by: Noogle on 31 January 2016
I'm re-jigging my living room and taking the opportunity to re-configure my audiovisual setup.
I'll be taking delivery of an NDX on Tuesday and am planning to connect the TV audio output to the NDX using Toslink optical.
I have a MediaCenter PC in the diagonally opposite corner of the room to the Naim rack and would like to connect it to the NDX. Will feed the cable under the floorboards - about 7m. The choice of cables is between RCA phono and BNC co-ax. Am I correct to assume that BNC co-ax is the preferable option here?
Also, can anyone recommend a decent half-height PCIe audio board with a BNC co-ax digital audio output?
