Happy new year, or maybe not...
Posted by: BPhotographer on 01 February 2016
Hi Folks,
How does a great story starts?
A new NDS, new 555PS DR and new full-loom SL cables arrived.
The speaker cables came first, it was a big difference in SQ, it seemed that every bit of the music is extracted and it was good,
I loved the SQ and decided it worth the money.
Then the XLR cables came and at the beginning it was a disappointment; the lively sound has stumbled. However it kept improving over time and after 2 weeks the bass became much deeper and the overall sound became more prestigious and dark as suit for naim.
I loved the system that way. The CDS-2 really shined, superb sound quality with the disadvantages of the CDS-2 (a little bit stressed sound, edgy HF and a relatively unnatural sound in compare to my LP12/NAT01/Chord Hugo).
I said myself, "naim did a great job with the cables, the forum praises the NDS so much, especially with 2x555PS, I listened to the NDS in friends' systems and it overtook the Hugo, and lets hope it's the end of the road for Hi-Fi".
So I made the order believing that when it will come it would be the best system for me (after the break-in period of course).
At the beginning, it was not bad... it was rather refined and after some time it was very natural (I listen mostly to classical music). Sometimes I felt an elfin capacity to render changes of timbre that can be properly breathtaking. It was very musical. It was with the new 555PS alone.
When I added my 555PS so now the NDS was connected to 2x555PS DR, it was a game changer in terms of technical aspects. It sounded very Hi-Fi, but like other non-naim competitors components.
Then, it became worse.
It's now 2 months later and the sound is harsh, unpleasant and not engaging at all.
I read that the 555PS and the NDS need some time for the burn-in process, but it should be good, at least!
It's a ridiculously expensive source, more than 20k pounds (if you count the Super lumina IC).
At the same time I also bought a new Supercap-DR for the Superline, and it sounds good, better than before (with my Supercap non-DR),
so two months are good for the Supercap but not for the 555PS?!
What next guys?
Should I wait some more time?
Should I listen to people like 'GARY YEOWELL' and 'JAMES L' and think that with the new SL cables the soul is missing and the music is not as enjoyable? (here)
I tried to replace the Din-Din SL with my Hi-Line and it sounded wrong (almost broken); especially too bright.
In regards to NDS/555 vs NDS/2x555:
1. With one PS, the sound is richer, more engaging, more 3D imaging and has a sense of a reproduction of a live performance,
and it is dull !
2. With two PS, the sound is more Hi-Fi, more in-the-room (a live performance), everything is bigger, much much lower noise floor and clean and detailed. But it separates the instruments, not in a good way. The orchestra is not there, but a plate of tones of violins, trumpets, drums, etc. coming from the wall.
Yes it has a deeper bass and a better clarity of HF, but it is dull !
To do/Not to do:
a. Wait. Be patient. The NDS and the 555PS sounds wrong now, but it will sound far far far better in X weeks.
b. Get back to the old cables (including the NACA-5, old XLR Hi-line/not HL...)
c. The speakers, SL2, are not designed for the new DR, SuperLumina things, do something at that area.
d. 500 DR?
e. ?
[My system: 500, 552 DR, NDS, 2x555PS DR, LP12, Armageddon, Aro, Superline, Supercap DR, SL2, Fraims, SL cables].
Thanks,
BP.
